Connecting Rod Length
Results 1 to 11 of 11
    Senior Member Can Am 75's Avatar
    Default Connecting Rod Length
    What is the longest rod you can put in a 350 Chev? It can be any crank as long as it has a max stroke 3.500", standard deck height block. Is there a formula for figuring this out?
    Jun 2010
    Quote Originally Posted by Can Am 75 View Post
    yes there is a formula
    Jan 2011
    Mickleton, New Jersey
    6.125
    Jun 2010
    damn broken interweb what Jim said .......
    Close to the water...
    You can spend extra bucks !!!
    Custom pistons and rods can be made
    Is there some special need to run a extra long rod ?
    I would stay with of the self parts if I could
    I have an idea and I am pretty sure Jim Clauss can figure it out already. I know anything can be made, the pistons in my 500 inch Pro Stock motor are custom made for my bore, stroke and rod length. What do you think Jim is it worth it?
    Default ou
    I can tell you straight out, if this is for a SE, your going the WRONG WAY!!
    I can't begin to tell you the power hiding in one of those things, and you aren't going to find it with some long ass rod.
    Senior Member stoker2001's Avatar
    Folsom,Ca
    is it really that important these days
    love my short 5.315 arms (on 3.4"stroke) in Windsor 8.2" block
    slug Compression hieght at 1.175" which gives rod ratio of 1.56
    run the piss out of it on road coarse and street with no issues
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
    Quote Originally Posted by stoker2001 View Post
    Not only is not ALL THAT, but longer in some applications is a negative. If there was ever a reason NOT to use a rod that long, the SE class is it. If they are using the "HOLY GRAIL" of Se cylinder heads, its a double negative.
    Go on...
    A 1.0" pin height is about the shortest you'll find off the shelf which means with a 9.0 deck you could run a 6.25" rod. That's a 1.78 ratio. If this is for a higher rpm range endurance deal it's not a bad combination. I wouldn't see any benefit at all in spending more money on custom parts.
