Cam??
Results 1 to 6 of 6
Cam??
    Sep 2012
    Default Cam??
    I have a gen 4 496, 10.1 compression, alum head,s 118 chamber, tunnel ram , over transom headers, ab impeller. Question is, will advertise 295 in, 305 ex, @ 50, 262in :272 ex, with, 670 lift, 110 lsa, is it way off what I have? Thank you.
    El Cajon, Ca.
    Quote Originally Posted by Bobbylisa View Post
    If that's what you got, it should work just fine. Obviously, more information would help get you a bit closer to optimal, but as far as being in the ballpark... you're fine.
    The Bostick®
    Tri-Cities, TN
    Thats enough duration to make max power around 6700 to 6900 rpm. Seems to big to me.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Sep 2012
    Thank you.
    What is it goin in?
    Chris, ls cores go down any? I need a bigger cam so does my uncle and hope'n to get u to do em.545 lift has done ok but lookin for more flow so 20lbs means more(as much as ya can get outta the stock ls heads we have, have already printed off nice flow sheets for both our heads by reputable ls guru that flows em in stock form).we ll buy two at same time this winter so pm me a price when ya gta chance.be in touch around nov for the cams, we re not sure what ci billy will be, he's wantin a big ci ls alum deal so he may change from 325ci to 408 , waiting on him to make his mind up.im happy at 325 on my deal jus want it doin all it can.
    Tri-Cities, TN
    What is it goin in?
    Less core mfg so price has gone up some, $30. Just had a customer run 9.38 at 148MPH with 12# on stock bottom 6.0L Ported OEM heads with Mahle pistons and oliver rods. The things are amazing.
    Chris Straub
    Straub Technologies
