Starter/Flywheel
Results 1 to 3 of 3
Starter/Flywheel
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Default Starter/Flywheel
    Hey guys, Had my Truck yesterday at the cruise/car show......Upon starting....had a slow crank/bumping/jumping, shake the truck start.....Took a couple cranks to get started......Started, idles nice.......thought I'd crawl under the truck and check it out today........found areas on the flywheel missing teeth.....starter gear looks worn, but no teeth missing. Also, grabbing the gear, seems to have some play in it...not much....just some side to side...up and down.......Never had this happen before.....any ideas? I'm guessing.....cheap flywheel for one, maybe worn starter bendix? Its a GM ZZ4 350 SBC.....I saw writing on the flywheel.....Handwriting, That said, "New Age". Not sure what that means......Starter seems to be a mini type.......Shoehorned in there, and with the headers blocking view, cant really tell what it is......I thought I counted 9 teeth on it........Anyone have any ideas what could of caused this? All bolts are secure holding starter.........Thanks, Dewey
    I’d rather live with a good question than a bad answer.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Flywheel bolts to torque converter is what i would check, if they are good u may be replacing a flywheel, which u maybe already be in need of
    Oh I need a flywheel for sure....just don't know why it happened.....all bolts are tight ......I'm thinking crap flywheel ......it's like...1" of flywheel distance ....2-3 teeth missing in 3 areas.....don't think my back is up to it pulling tranny out on the floor in my garage.......
