Head stud question!!!!!!!!!! NEED HELP
Results 1 to 14 of 14
    Member Jmicus's Avatar
    Jun 2013
    New England
    Default Head stud question!!!!!!!!!! NEED HELP
    SO i have a gen 6 502, it has 12562934 00 and up gen 6 marine heads. I ordered 235-4308 arp head studs which i was told would work for the gen 6 502. Well they came in the mail after 3 weeks and they arnt even close. The head bolts i pulled off are 2 different sizes, the arp kit i got has 5 different size lengths and the longest size isnt even close. I cant find any tech support at all on this any help would be appreciated. Trying to get the boat rebuilt and boosted before the season is over!!!
    Quote Originally Posted by Jmicus View Post
    If you call ARP, they are pretty helpful.
    Something doesn't make a lot of sense here. That's the right part number. But what makes no sense is you say that the bolts you removed were only 2 different lengths. Never seen a BBC that only has 2 bolt lengths.
    When you say the longest "isn't even close" you don't say if they are too long, or too short.
    Jun 2013
    New England
    The longest studs are way too long. We were pondering over beers this issue as well. All the bolts are side by side and there are only two sizes. Ill post up pictures tomorrow of the studs vs the bolts.
    I called ARP, SUMMIT, and some other performance place.....
    ARP was the most helpful with this helpful piece of advice...."GOOGLE IT." their tech support is a bunch of morons. I ordered the 135-4001 and they will be in tomorrow. Ill keep you posted. On a gen 6 with the marine heads i listed the 4308 studs will not work. Its either that or they took a handful of studs threw it in my box and sent it...
    Jun 2013
    New England
    this is my first time studding a 502, I didnt even try to put the thing together after looking at the studs, there are 5 different lenghts of studs, do you know which ones go where. Im familiar with the kits that contain 3 different sizes but 5 is completely foreign to me
    Jun 2013
    New England
    THeres a pic of the largest stud compared to the largest head bolt. As you can see its not even close......
    Those are the studs i ordered.
    And theres a pic of my head bolts, as you can see there are only two sizes.
    Jun 2013
    New England
    I picked up the 135-4001 ARP head studs today and they fit perfectly. If any one has the same issue as me, that would be the kit to get not the ones listed above.
    someofamitch
    Draper, Utah
    Wow! Is arp taking the other set back?
    Jun 2013
    New England
    Quote Originally Posted by Terminal Velocity View Post
    i have to give them
    a call. I called tthem and they recommended that set for my motor. So did three other speed shops I'm not sure why there was such a mix up.
    Nov 2009
    Just a reminder: Don't forget to put sealer on the studs.
    Jun 2013
    New England
    Quote Originally Posted by Checkmate281 View Post
    even on the gen 6? none of my holes poke into the jacket water passages, i Checked all of them with a flash light.
    Nov 2009
    If the bolts you took out had sealer on them why wouldn't you?
    Jun 2013
    New England
    a good point, I didnt have any on me at the time (shitty excuse). And gen 6 blocks have blind holes so i didnt see the need. I guess time will tell....
    Jan 2013
    Could be everyone has used sealant so long they may be fearful switching to any other lube may change torque values.
    The old adage, 'If it ain't broke.....'
