B&M 174 belt clearance problems
Results 1 to 14 of 30
    Member Jmicus's Avatar
    Jun 2013
    New England
    Default B&M 174 belt clearance problems
    I have a B&m 174 and a 502 502 crate engine. The motor has a v belt setup and the snout is just to short for the setup i have. What do i need to make this work. DO i need to switch to a serp setup for this or can i getaway with a different v belt crank pulley. Also do they have a pulley spacer up top for the snout pulley?
    Any help would be awesome.
    Close to the water...
    Quote Originally Posted by Jmicus View Post
    I think that blower is to small for a 502
    I ran one on a small block once
    That was mentioned in his very first thread.
    http://www.performanceboats.com/dyno...ld-advice.html
    In not sure I understand the whole "v belt" thing. What has v belts? The accessories, or the blower???
    The blower and manifold are designed for use with a 3 v belt crank pulley for accessories.
    Jun 2013
    New England
    The accessories are all on v belts. There are three separate belts for all the accessories. When the blower is mounted on the motor the lower pulley sticks out two inches farther then the pulley on the snout. The previous owner have it on a v belt accessory motor but apparently it was a different style. If i switched to a serp setup i would at least have room to work with.. I was seeing if any one had a similar issue and how it was solved.
    There are 2 different 3 groove pulleys for a BBC, a deep on for long water pumps, and a shallow one for short water pumps. You need on that is shallower from the short water pump design. You will have to re-space the stuff that is driven by the v belts, but that's easier and cheaper than a serpentine belt setup.
    I bet your lower pulley has a deeper dish than this one.
Name:	BBC lower pulley.jpg
    Jun 2013
    New England
    Thank you!!!! I was at a stand still with this issue haha. I will look into this. Now i just need to find one of those haha
    Think long and hard about using a 174 BM blower on a 502
    I don't think one person here in the dyno section would
    I could make more power N/A with fewer problems
    just my 2 cents
    That one was on E bay.
    LINK # groove BBC pulley
    Summit and Jegs sell billet alum ones too.
    LINK: billet pulley
    You can usually find one in a wrecking yard as well.
    Jun 2013
    New England
    ill take a pic of what i have just to confirm
    Tower Park Resort, Lodi, CA
    just my 2 cents
    x2
    Jun 2013
    New England
    Jun 2013
    New England
    do you think the thickness of the harmonic balancer could be an issue as well,
    Jun 2013
    New England
    just my 2 cents
    Im currently looking for a larger blower for the boat. Regardless of blower size i will still need to get this figured out unless i go with a centrifugal unit.
    If the blower pulley and lower blower pulley line up, then the problem is not with the balancer. If you move the balancer mounting point, the lower pulley will not line up with the blowers pulley. DO YOU NEED TO MOVE THE LOWER BLOWER PULLEY????
