pushing alittle oil out valve covers
Results 1 to 14 of 19
    Senior Member Skydog's Avatar
    Jul 2010
    Default pushing alittle oil out valve covers
    Under high rpm and boost I am pushing alittle oil out valve covers any real fix for this,other than a puke tank?
    Ty
    Jul 2010
    4" Tall Aluminum Valve Cover Breather - CP Performance
    I have these but are not 4" tall more like 2"
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    pan evac
    Lake Havasu az.
    Breather/oil separator with a nipple in each valve cover, to a hose, a AIR check valve and a pipe welded into each collector. Rings in my motor were used when i got them, honed the cylinders...twice, put the rings in another block.....the only time it has pushed oil out is when v/cover grommet ripped. My valve cover don't even have baffles in them.
    Sheriff Joe Arpaio
    Jul 2010
    Vacuum pump set up?? Anyone running one?
    WV
    I am running them on my BBC, twin engine, haven't tested on water yet, but did well on dyno. I bought the Aerospace Components off Ebay.
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by Franger View Post
    pan evac
    Gotta agree with Dave on this one!
    Jul 2010
    Sorry but you mean?? A puke tank??
    Aug 2011
    Wasilla, Alaska
    First things first, how bout telling us what you're running for exhaust.
    Do a search for "pan e vac" or "pan evac" or ?? They work well
    Jul 2010
    Cmi big tubes wett
    Jul 2010
    I think I see what you are saying run a hose from valve covers to exhaust/tail pipe.
    Quote Originally Posted by Skydog View Post
    After puking oil out all season on a big inch nitrous motor with breathers, we are switching to a vacuum pump. I've used Aeromotive Billet but some have had problems with them in lake/street applications where you get a lot of time on the motor. If the motor sees a lot of run time, I'd look at a GZ motorsports pump. I've run them as well and am acquainted with the owner. He's a good guy and works pretty hard for his customers. A pan evac is a good choice if you run dry headers, but not my first choice for a wet exhaust.
    Jul 2010
    Thumbs up
    Thank u , yes I will add this in the winter, this is the last little thing I dont like. Have huge money in motor why stop now to make it 100% right.
    Ty Skydog
    Member D Johnson's Avatar
    Jun 2013
    Yorba Linda/ Willow Valley
    Being this is not a drag race motor it should not push oil out of the breathers if it has typical valve covers with breathers, this sounds to me like the rings are not seated good. Is the oil getting contaminated with fuel fast? My experience with big HP offshore type motors is when built right and good ring seal motors do not push out oil.
