Tall deck BBC mounts ?
Results 1 to 12 of 12
    Bullhead city AZ
    Default Tall deck BBC mounts ?
    I have a chance to pick up a tall deck BBC 454 , but will it still fit my rail kit mounts? I dont want to have to change everything and if so F That
    Cantard 71hallett's Avatar
    snow bank
    Everthing is the same but .4 added to the tops of the cyl.
    Bullhead city AZ
    Sooooooooo..............is a tall deck a good engine for a boat ?
    Quote Originally Posted by 468Bahner View Post
    It's a great base for a stroker engine, you can use longer rods. The "stock" 454 truck tall deck is a truck engine, 4 ring heavy piston, not designed for performance.
    The biggest issue is if you want to use your same intake and distributor, you will find they don't fit. You can use spacer plates for the intake, but still need a tall deck distributor, or you can buy a tall deck intake, many of which now will use a standard distributor.
    Bullhead city AZ
    The specs.
    Chevrolet Mark V Tall Deck BBC 454 Professionally built to be an estimated 600 HP-- Never Fired.
    +Mark V 454 Block, 4 bolt mains
    +502 New GM Forged Steel Crank
    +Heavy Duty Racing GM 7/16 Forged Rods
    +9 3/4:1 Comp. TRW Forged Pistons .60 over
    +Internally BALANCED with flywheel
    +Roller timing chain
    +Crane Roller Cam
    +Heads Ported and Chambers cc'ed (ovals)
    +Extreme Duty Manley OVERSIZED Valves
    +Manley Valve Girdles
    +Crane Triple Valve Springs
    +High Volume Oil Pump and Deep Oil Pan
    +Edelbrock Aluminium Intake Manifold
    No Carburator, Distributor, Roller Lifters, Push Rods or Roller Rockers.
    This was a no expense spared build, highest quality everything. Real Deal, Serious Motor looking for a serious buyer. I have over $8,500
    2 Sav, you changin your mind again??? J/K
    The specs.
    +Crane Roller Cam
    As I told you in PM,, something seems not right. Stock GM 7/16" rods would require the use of a "truck" piston, similar to the stock 4 ring model. Certainly not a "no expense spared" kind of engine. The "oversize valves" may be covering up sunken seats in a truck oval port head.
    This one would require careful inspection prior to purchase in my opinion, including but not limited to removing at least one head, and probably the pan if it is bolted on.
    Bullhead city AZ
    No.. it would have been a half the money down thing and payments. I liked that idea , get a motor in the boat this season
    But thanks to the few...."You know who you are" that set me straight. It dont look like i can take any shortcuts , and nobody else wants to sell one on payments.....
    Too risky i would think
    Bullhead city AZ
    Barry , you have been more than helpfull
    Thanks again.......
    I will be glad to sell you one on "payments", but it doesn't get to go home with you until the final payment.
    Bullhead city AZ
    The only problem is , i dont know how i would get it back to Bullhead.
    Otherwise as 'Tone loc' would say
    Lets do it
    Newton Ks.
    The GM Rod with 7/16" bolts was the racing High Performance rod, generally only found "stock" in the L88 427's and the LS6 and 7 454's.
    Both are 4340 steel alloy
    P/N 14096151 in a pressed pin style (knurled shank bolts, LS6 & LS7 454's)
    P/N 3969804 in a full-floating pin style (the HD racing version) 7/16" ground Boron Steel bolts. Green color coded rod, top of the line.
    H.L. Mencken
