silicone ?
Results 1 to 9 of 9
silicone ?
    Aquacraft Eddie's Avatar
    El Paso TX.
    Default silicone ?
    hi, I was putting the timing cover on the motor, along with the oil pan, and i did something stupid, which isnt new, i had put the black permatex rtv silicone on the timing chain gasket and then i put it on the water pump openings and didnt even realive it till the next morning! the timing chain cover and (water pump) is an old glenwood plate, and the plate covers both (chain and water pump) i was so into putting that shit on i didnt put the grey water pump silicone where the water pump openings are, so the question is has anybody else done this? and did it leak water? I really hate to take the oil pan off and replace all gaskets just because of this! so is black rtv silicone water resistant?
    280 Profile Cat W/575sci JRider's Avatar
    Lansing MI / Deerwood MN
    I believe all silicone is
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    It will be fine, run it
    Dec 2010
    Sapulpa ok
    That's all I use.
    Led
    Led is offline
    Jul 2010
    Quote Originally Posted by piston in the wind View Post
    That's all I use.
    me too, but mainly b/c i dont want to get that shit all over everything else i may touch, especially after massaging the lower timing cover gasket
    El Paso TX.
    That's all I use.
    Thanks for the help, I figured it would be fine but just wanted to make sure, I think the grey stuff that is for water pumps and thermostats is glycol resistant, but since this is in a boat and no antifreeze it shouldn't matter, I'm just used to putting that grey water pump stuff on car water pumps and thermostats, not used to working on a boat motor......it's been a long time
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Eddie View Post
    I've used the black on everything big rig coolant systems 500k miles no problem
    El Paso TX.
    Ok thanks, what about the exhaust logs? I have old glen wood water cooled through hull logs, and I'm putting them together, at the end of the log there is a gasket between the manifold and the down part or snail , but I don't have snails, anyway do I need silicone on those gaskets or are they dry? I don't remember how it was when I too it apart?
    Dec 2010
    Sapulpa ok
    Smear it on and just snug them down wipe off the extra and come back the next day & pull them down tight
