dominator 3 cuircut wont idle and surges while cruizing some times
Results 1 to 14 of 70
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    Default dominator 3 cuircut wont idle and surges while cruizing some times
    holly 1050 90 jets squared otherthan that havent touch it any help would be great thanks
    dat da dat tat dat da tat, like a rev limiter? yeah, that's a 3 circuit, get used to it is this a high compression bbf or something? that's big jets, i run 88's on a 13.5 to 1 505bbc.
    Golden Shores,AZ
    it's a 514 10.2 big sollid roller any help would be great
    Bullhead City, AZ
    What air bleeds are in it ?
    They are # just like jets.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    Quote Originally Posted by 78CoLeBBF View Post
    put a 2.5 power valve, bet you don't have any vacuum
    also pull the sight plugs and make sure the floats are right
    Golden Shores,AZ
    air bleeds stock so what ever holly puts in it is there, is there only a power valve in the front cause there's no power valve in the back metering block
    Golden Shores,AZ
    float level is perfect come on need some help before i sell this [email protected]
    pull out the 3rd circuit air bleeds, drive it and see how it does. if it cleans up alot, leave the bleeds out. remember, when you're setting idle on a dominator, you HAVE TO ADJUST BOTH IDLE SCREWS THE SAME AMOUNT don't just adjust the frt and think you're doin it right, cause that's not right. my mixtures screws are all 4 about 1 1/2 turns out.
    Golden Shores,AZ
    will do and yes for every 1/2 half turn i go on the front the back gets it is there a power valve in the front metering block and can i change the air bleeds
    nutha thing i've noticed about dominators, they like alot of timing at idle to get the vaccum signal up. i'm locked at 36 and after the initial warm up, i can idle around all day and never have to tap the throttle to start the boat warm.
    a.k.a. "Mean Pair" Nice Pair's Avatar
    I want out of Kalifornia
    Bolt on a Holley R8082-1 and never look back. Just changed out some 3 circuit 1050's to 2 circuit, like driving a new boat. Idles, accelerates, no 4 cycle in mid range (3rd circuit fuel dump) no black soot all over boat. Call Tom @ Holley Tech > 270-781-9741 ask him about 3 circuit in your application. The 3 circuit carb has some extremely long idle slots, so changing metering blocks (making your carb 2 circuit) just creates a new set of problems.
    Lurker
    NC
    Very good point Tom!
    That could fix his idle and surge problem depending on were his timing advance comes in.
    Surge (lean or timing) maybe a little differant than a thrid circuit (rich) blubber.
    I have duel 3 circuit dominators on my boat, and with a little bleed swap it works great at all throttle openings. And like you said, tap the starter button and it fires right up.
    I ended up with 80 intermidiate bleeds to clean it up, and a little idle screw adjust. The timing is locked at 31*.
    Golden Shores,AZ
    thanks guys gonna try some stuff
