Idle Problem
Results 1 to 3 of 3
Idle Problem
    Apr 2012
    Tucson
    Default Idle Problem
    I went to the lake this weekend and came home with a problem that didn't exist last trip. My boat wont idle under load. 18' jet with 468. Running 2 x 600 cfm holley vacuum secondary. It idles fine on the trailer, put it in the water and it will die. I turned up the idle set screws but to keep it running, but when i set one or both just enough to keep it running, I'm in the main circuit and start running rich. I only have 1 trip left this year and will rebuild over the winter but any help would be great. Thanks Steve
    someofamitch
    Draper, Utah
    Quote Originally Posted by cubegenie View Post
    Check your timing. Something may have moved. Long shot im sure but seen stranger things. And doesn't cost anything.
    Jan 2013
    Magic Mountain CA
    My recent idle problem ended up being that my advance springs were broken. Springs lasted about 8 years.
