"Pop"
Results 1 to 9 of 9
"Pop"
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Default "Pop"
    Hey guys,
    Was wondering if I should be concerned about this , while warming my engine in the drive for an oil change.....also heard last time out on the lake at the dock warming engine......."a slight pop" out of the exhaust while I'm slightly tapping throttle to maintain a idle.....after idle is established, and engine warmed.....a throat clearing tap....950 rpm-2,000rpm....I get a slight "pop" out of the exhaust ......while in gear.....engine takes all I can throw at it....question....I'm I hearing just a slight "lean pop"? Hate to mess with the carb....1050 worked over....four corner adj.....runs well....other than this slight pop....thanks, Dewey
    I’d rather live with a good question than a bad answer.
    Tri-Cities, TN
    Quote Originally Posted by Deweydaddy View Post
    Hey guys,
    Dewey,
    Sounds like carb. I would start there. Other than the pop how does she run? How responsive is she?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Dewey,
    Chris.....it's amazing....what a difference!!! Instant power....nice cackle out of the exhaust.....Mike did a great job with the build....thanks for all your input too.... Dewey
    Lean is almost always thru the carb, not the exhaust. Is this a slight pop that is off rhythm, or a very noticeable POP on the header?
    Senior Member bp298's Avatar
    LHC
    agree. but just for grins, i'd thoroughly check timing.
    Hey guys, Thanks for responding, its a pop out the exhaust, when I rev to maybe help warm and to get a good idle......I also don't stand on it out of gear. Its happened once or twice when I got to the sandbar too.....I push the in and out lever out gear.....and while still gliding into sandbar, I'll give it a lil stab, and a pop comes out the exhaust.....not all the time tho.......
    What's timing, and are you running a mechanical advance. Has this motor ran before and you changed the cam, or is it a new build?
    Yes it's a new build....msd dist with mech adv.....only had the new motor out 5-6 times.....I set timing to 34 full adv....it's all in by roughly....2,600 rpm's.....haven't run the boat in a couple weeks on the water.....past few days in the mid 90's!!!! Major cold front coming through now.....sever storm warnings....66 for highs this weekend.....don't think I'll do much with it this weekend......
    Apr 2010
    Rocklin, Calif.
    Cool
    Hey guys,
    With four corner Idel make sure there ALL adj. the same...had the same problem and One air-fuel screw was out 1/8" turn than the rest
    cleared it right up
