Which fuel pump - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 43 to 46 of 46
Which fuel pump
  1. #43
    Quote Originally Posted by hava life View Post
    I have the same problem, but I do appreciate all the input on the pump issue. Now the problem I have is what regulator did I get from Holley and why did the other 2 not work? No return call yet by Holley.
    That is odd, because the 704 is an extremely reliable regulator.
    Yeah, Gen engines can be a pain due to no pump provision.
    Dead Member Hyperpasta's Avatar
    Nov 2010
    Glendale, AZ
    They have yet to build an electric pump that is as reliable as a mechanical or pump the same fuel volume dollar for dollar. People run electrics because they think they racey. Funny thing is, out side drag racing, most race boats run mechanicals. I guess most lake/river boats using electric pumps fall under the category of "drag" boats
    I hear you Bob! But I have a Fuelab Pump on my diesel truck pumping #2 at 65 PSI all day long. Had other pumps fail but this bugger is going strong. I ran it for 3200 miles straight stopping only for 2 short road side/Hwy naps. I'll run my F350 normally 10+ hours at a time until my body can't take it anymore, then let the wife chase grocery's with it. I've run it in super hot conditions here in the desert and in the low teens were the #2 gets thick. It hasn't failed me yet in over 5 years. The truck has 110 gallons of oil onboard and getting it to the motor has not been an issue yet. Is it the best I don't know? It's just after going through some pumps this little bugger has caught my attention! No I don't sell them.
  4. #45
    Quote Originally Posted by Hyperpasta View Post
    Not saying there aren't electrics out there that don't work. There are some killer electric pumps, that come with some killer price tag attached to them. I'm saying dollar for dollar, gallon for gallon, lbs for lbs, the mechanicals have them beat. On virtually any electronically controlled fueling system, electric is about your only choice.
    making pressure is as hard as falling out of tree. Moving fuel and making pressure is a different story. I doubt the pump you are using for that diesel is being asked to move 130 GPH while making 65 psi.
    It take about 35 to 40 minutes to burn thru the 55 gallons my boat holds. You better bring a stout electric pump if your going to move that on a constant basis.
    Fuelab does make some nice shit though, and few people recognize that.
    Nov 2010
    Glendale, AZ
    Your right Bob, I'm just under 100GPH, but they do make pumps that will move gas at 200GPH @ 20 psi. The only reason I mentioned this pump was the fact, that like you I've seen many electric pumps fail. Even with the Fuelab in my truck, I keep wondering if this one is going to leave me from my past experiences. It just keeps on running......just had to share. I agree also on costs too!
