Extended oil pump pickup question
Results 1 to 5 of 5
    Oct 2011
    Default Extended oil pump pickup question
    I just bought a Dooley BBC V drive pan but need a pickup. Will any BBC extended pickup, regardless of brand, work with this pan? Also, is a windage tray necessary? Application is a family ski boat.
  2. #2
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Dooley pans ususlly have cap mounted tray. You can get a tray and pickup from Dooley
    QE 439 Twin Turbo
  3. #3
    Apr 2012
    Tucson
    Dooley windage tray part number 011002, $65 and the pickup part number is 011013, $93. Pretty sure you need new cap bolts for that tray.
  4. #4
    Oct 2011
    Thanks for the part numbers! For a recreational use boat, sub 5000rpm, stocker 330hp motor, is the windage tray mandatory? I've always owned DD inboards before and always used just the factory pan.
  5. #5
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    If your referring to a MK 4 BBC, and as long as there are no attached tabs inside of pan or anything else to interfere with proper pan alignment, the stock tray should work out just fine-I have used them in the past. If I remember correctly, the aftermarket trays that use the main cap bolts usually require 2 additional bolts as well.
