boost gauge fluttering
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
    Feb 2009
    SF Bay Area
    Default boost gauge fluttering
    Anyone know what would make the boost gauge flutter? Only does it in boost, not vacuum, and gets worse as pressure goes up. Needle had always been stable at any pressure. Compression is good, all cylinders within 1 to 2 lbs.
    Surprise, AZ
    Boost leak? Bad gauge?
    Feb 2009
    SF Bay Area
    Yeah, maybe the intake manifold gasket let go; the gauge's hose is tapped in near cylinder #7.
    Kent, WA
    Blower base gasket, o-ring or pop off plate ?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    How close to the valve is the port?
    QE 439 Twin Turbo
    Dec 2010
    Sapulpa ok
    Check valve springs ??
    Feb 2009
    SF Bay Area
    A couple of inches from the cylinder head. The gauge's needle has been stable for nearly 200 hrs (3 engines).
    Feb 2009
    SF Bay Area
    Quote Originally Posted by piston in the wind View Post
    Will do, was going to check the lash anyway.
    Feb 2009
    SF Bay Area
    I think I will change the blower while its apart anyway; I will check the pop off plate and gasket.
    If this is new phenom on an existing engine. I doubt its the location of the line in the manifold.
    A leaking pop off or base gasket is nothing more than a leak, not unlike a open intake valve, but constant instead of cycling. A leaking pop off or base gasket would only smooth out any pulsing in the manifold, not increase it.
    However, leaking or bouncing intake valves are another story. Just one badly leaking intake can create pretty severe manifold pressure spikes.
    Feb 2009
    SF Bay Area
    gn, what you are saying is what I was afraid of but it has perfect compression in all 8. Maybe a valve spring problem?
    Quote Originally Posted by SFOcean View Post
    Either valve springs or the lash is really loose the valves are slamming the seats when they close instead the last of the cams closing ramp sitting them down gently.
    What brand/size roots is this thing?
    Feb 2009
    SF Bay Area
    Blower Shop 8-71 @ 16% over, 6 lbs boost; changing to Blower Shop 14-71 so I can slow the drive down to 5% over and net 10lbs boost. It is intercooled.
    Oh, and the lash was set cold at 12 intake, 16 exhaust 15 hrs ago when the engine was built. Crane wants 18 across hot.
    If those settings were done cold, they are probably a little loose hot, specially the exhaust. Alumin heads usually require .006 to as much as .009 tighter than the hot lash.
