Gear drive with Magnaflow pump question?
    Member TOMSS1's Avatar
    Aug 2010
    Default Gear drive with Magnaflow pump question?
    I have an Erson 3 gear drive I want to run on my blown BBC. I am going to have to modify the cam gear cover to accept the water pump. My question is will the pump extension and pump setup keep the cam end play correct assuming you set the end play with the t slot depth on the extension? Probably a dumb ? but I don't have a lot of boat experience let alone with a gear drive. Thanks Tom
    Quote Originally Posted by TOMSS1 View Post
    Yes you can use the pump to control cam walk. Just get the end play correct.
    Aug 2010
    Bob- Thanks as always for you valued advise, anything else on this gear drive deal that I need to pay attention too? Thanks Tom
    No, they are a pretty straight forward unit. I kind of wish they still made them. Infinitely better than a dual idler POS, and a lot cheaper than a Milodon.
