Boost/Vacuum reference port question
Results 1 to 6 of 6
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Boost/Vacuum reference port question
    Can someone explain these ? I'm upgrading my mech fuel pump to a Clay Smith which requires a regulator (my old Holley did not). Do I need a regulator with a boost/vacuum port ? Why ? Can't I just set the F/P at 9lbs. and go ? Thanks !!!
    P.S. Blown BBF running +9 lbs. on 92 pump.
    Cantard 71hallett's Avatar
    snow bank
    Blow through carbs need reference, draw through do not.
    Enumclaw, WA
    I have boost referenced carbs now, so I don't need the boost/vacuum regulator ? Even if I don't I'd like to understand how/why that type of reg works.
    blow thru require the fuel pressure to increase 1 to 1 with boost
    pressure to maintain the base fuel pressure.
    if you did not increase it and started with 5psi fuel pressure
    and added 5 psi boost pressure your needle and seat would see
    0 fuel pressure, because of the added internal pressure
    from boost. IMO
    Enumclaw, WA
    from boost. IMO
    That makes sense, thanks !!!
    snow bank
    Quote Originally Posted by DaytonaTunnel View Post
    You can use a reg with the boost ref port you just leave it empty if that helps.
