bbc dist.
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 46
bbc dist.
    Senior Member slotracer's Avatar
    Default bbc dist.
    ok i have a weiland manifold and it sets the blower further back so a reg. dist. will not clear has anyone else had this problem and how did you fix it? help i almost have all the stuff done to the front of the engine so its on to the back of it.
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Hondo Jet blown540's Avatar
    Holland, Mi
    Welcome to my world Check your drive allignment, if it's good like it is just get a msd flat top dist. $368 My allignment is off so much I'm getting another manifold. The blowershop people told me that their manifold as well as littlefield and mooneyham's places the blower a full one inch further forward then weiand. They told me 1/2" on the BDS unit. Check the spam section Jim has a polished blowershop piece for sale
    Kingman/Golden Vly, Az
    Quote Originally Posted by slotracer View Post
    i have a SBC Weiand blower manif that also sets the blower back...Dale Welch sells a set of Timken sealed roller bearings that replace the old style ball bearing rollers & u run NO rear cover...solves the problem perfectly...i run a mag & it fits fine...i think they are @ $40 set
    www.Dale_welch.com
    FastRat
    link no worky
    slot
    87 eliminator
    Stockton, ca.
    link no worky
    my bad lol.....www.rpmcat.com
    ph# 1-800-468-7637 or 913-788-3219
    located in K.C.
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    buy an off set drive and a Mag
    [/SIGPIC]
    Quote Originally Posted by Lucky View Post
    i thought of this but have no clue where to buy them at
    slot
    87 eliminator
    Stockton, ca.
    why spend the $$$ that u dont have to?
    FastRat
    Ukiah,Ca
    FastRat
    cause they work well !!! Check out the ads on dragboats.com there are always offset drives for sale I bet a few of the racers have some laying around
    another option is to run your distrubuter off of the cam .
    [/SIGPIC]
    located in K.C.
    hows this work? what do you have to do remove the rear cover?
    slot
    87 eliminator
    Stockton, ca.
    u remove the outside rear cover (2 piece)...inner has the bearings...take the retainer plates off that hold the roller ball bearings in place...take the bearings out & replace with the sealed bearings & put the retainer plates back on...put the bolts thru the inner cover all around & ur done...takes about 15-20 min...i'm gonna make a 1/4" alum solid plate that covers the rear for looks, but u dont really need it, except for looks...i'm just trying to save u a bunch of $$$...u can go the other ways that were suggested, if ur rich, cause none of that stuff is cheap or chng the bearings...u do the math...$40 against $400+...i personally spent the $40 & it works fine
    FastRat
    i understand this very well...they work fine, but, he is new to the blower scene & has had alot of trouble getting everything up front lined up (pulleys, idler brkt etc) so i was trying to save him alot of $$$...new/used parts are not cheap!...this is a fix that works just fine ...if any of u lived close to him, u could always go "help" him out!!!!!
    FastRat
    FastRat
    i would much rather do it this way. i was dreading spending another $3-400.00 dollars. i will give them a call. i checked their website and could not find the set-up. is there a certain part i should ask for? i would be interested in a cover also
    slot
    87 eliminator
    Stockton, ca.
    on there web site...go to blower parts on the left side of menu & scroll down & u will see them...P/N is W20-7050WIN...these are the one's i have in mine...cost: $35.95 shipped...they do not make a cover that will work cause of the set-back of the blower...u either have to make ur own as i stated or leave the outer cover off
    FastRat
