2500+ hp on E-85
Page 1 of 13 1 2 3 4 11 ... LastLast
Results 1 to 14 of 169
2500+ hp on E-85
    okie, lake Texoma
    H8-2-W8
    [email protected] first pass
    Kent, WA
    Damn !!!!!
    okie, lake Texoma
    I thought it was interesting when he spoke about how much harder he could lean on an engine when fueled by C-16 gas instead of the e-85 ethanol based fuel.
    H8-2-W8
    Senior Member Lildave's Avatar
    Aug 2010
    Bauxite, AR
    The tuning window is a lot narrower on E85. C16 is much more forgiving.
    Already miss the 310/562 2manymustangs's Avatar
    Steve Morse is the builder for this car, Tom Bailey's 69 Camaro... Quickest/fastest street car in the US... Tom Bailey's 69 Camaro Sick Seconds built for Hot Rod Drag Week is the worlds fastest street driven Camaro - Sick Seconds
    2013 Hot Rod Drag Week Champion
    First car to run in the 6's all 5 days!
    Record for the fastest pass in drag week history 217MPH
    Record for the Quickest pass for a street driven car 6.70
    Drove over 1000 miles and then went 6.78 at 217mph
    This is not a race car that is street legal.
    It is a street legal car that can also race
    Pat Eason, the voice of reason...
    Jun 2011
    spokane, wa
    Steve builds some of the BEST boosted engine ever seen!!
    Wanna bet Steve didn't run down to the corner gas station to pickup that E 85?
    Ada, Michigan
    How about this one,
    MMR Pro MOD GT500 sets NEW Worlds Fastest Modular ET and MPH record!! - Yellow Bullet Forums
    Those Ford mod motors are really making a strong show.
    I see you can buy a 5.0 liter all aluminum DOHC crate motor from Summit for $ 6,100.00
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    How about this one,
    Pretty impressive but it wasn't a crate motor. It was a filled specially sleeved Pro Mod version.
    QE 439 Twin Turbo
    Ada, Michigan
    I saw that they had a special block with about 351 ci.
    It must take over 3000 hp to run 6 sec flat with the ProMod cars.
    That's faster than nitro funny cars were running back in the 1970's when I got out of high school.
    The 5 liter DOHC 4v crate motor would be cheap and a good project motor for me.
    Might need to knock that CR down to 9.5:1 or so.
    There must be a significant weight savings over an all aluminum BBC.
    FORD got it right with the 427 cammer and they got it right with the OHC modular engine... I have owned many modulars in my cars/trucks and they are really amazing just in the garden variety passenger car form...
    New Port Richey, FL
    You like them better than an LSX? Or like the price better?
    QE 439 Twin Turbo
    Ada, Michigan
    I told myself that my next engine was going to be something with some modern technology.
    Pushrod engines seem way outdated to me. Valvetrain problems account for a good % of the issues I've encountered over the years. I heard that the valve spring pressure for a DOHC 4 v head is a fraction of what it takes for a pushrod engine.
    I thought the 1990 Corvette ZR-1 engine was a huge leap in the right direction but Chevrolet phased that out in favor of a glorified 1955 pushrod engine.
    I looked into getting one of those but a new all aluminum 5.0 L Ford mod engine is less expensive than a 20 year old ZR-1 engine.
    One big turbo on that 5 L Ford engine should have no trouble making 1200 hp on E85.
    BINGO, the seat pressure for a high rev pushrod engine is the root of its troubles...
    IF you look at the engine failures on a nascar track when they are running 9K plus RPM you will find out that it all comes down to the whole pushrod/valve/rocker/lifter/spring pressure (valve train failures)... the load on the valves from HIGH HIGH HIGH spring pressures to prevent valve float is what kills them at the RPMs... The inertia from the weight of all those components stacked up against the valve spring / fighting the valve/stem...
    The spring pressures on a OHC engine are nothing in comparison and those engines can rev much higher without valve float...
