Valve lash on all aluminum motors
Results 1 to 14 of 28
    Lake Havasu
    Default Valve lash on all aluminum motors
    How much lash do you subtract from the manufactures "hot" spec's when adjusting an all aluminum motor "cold"? In other words, how much do you compensate for heat expansion?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    We subtract .010 aluminum block and heads.
    QE 439 Twin Turbo
    According to my Reher Morrison book it's .004. I did this way, then warmed my motor and rechecked adjustment just to verify and they were dead on.
    From the book
    Mar 2010
    Clarksville, TN
    Foxwell told me to subtract .006. Iron block, lumi heads.
    Senior Member Itsahobby's Avatar
    San Jose Ca.
    Need to do my research before opening my big mouth. Checked around and found a few sites, including Crane:
    I'll delete my post.
    Sorry for the confusion.
    --Jerry
    Surprise, AZ
    Not to hijack the thread but, my cam card calls for .026 cold. Iron block, AL heads, should I be setting them different from the specs?
    Lake Havasu
    I was told by a very good source to subtract .010" Just wondered what others were doing
    Like Info said, .010 is probably the number. .012 would probably be the number in a car.
    Either is within the range of a valve lash loop, but I would use .010 number.
    Iron block, alum. heads, .006 has always seemed to be dead on from my experience. Only worked on a few all alum., engines and never did before/after hot/cold lash checks, but I'd start at .010 then check hot. Always check hot just to verify and .002" lash adjustment is more than I'd ignore.
    Ada, Michigan
    I set them at .012 cold and I get .024 hot.
    Jan 2011
    Mickleton, New Jersey
    I never see this much of a change? Now Hot does it get? Are they Chev. or Big chief Heads?
    Senior Member 65BEAVER's Avatar
    Nov 2008
    livonia mi
    Deck height, and the quality of the alum. I know this guy got his answer but I have some that are .002 cold .020 hot. A lot of junk I do is 11.6-12.0 deck. Billet blocks and heads grow way less than cast. Just my 2 cents don't need to stir the pot.
