??? about crank trigger
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default ??? about crank trigger
    I know nothing about them, other than I've read they're better. I want to learn more about why they are better. Are they hard to get working correctly ? Hard to set-up and wire ? Pro's and con's ? Reliability ? Thanks !!!
    Quote Originally Posted by DaytonaTunnel View Post
    As was posted in another thread, if you could see your timing and what it was doing with a conventional distributor, even the best racing dist., you wouldn't think the engine would even run.
    A crank trigger provides a much more stablel and accurate spark throughout the rpm range. They're esay to wire and easy to install. reliable as there are no moving parts, and no timing advance. If you need advance in your application, you'll have ot run a digital ignition with a programmable advance. Otherwise they work with most basic elecrtronic ignitions.
    Everything Scott said above.
    We have always checked the timing on our boat at 4,000 rpm after we pulled the engine off the dyno. It's amazing how stable the crank trigger is compaired to the dizzy. The timing at 4,000 use to jump all over the place after the crank trigger it's rock soild, no bounce at all.
    Don't even think about it just pull the trigger and buy one.
    Sleeper CP
    Yea what they said.
    San Diego, CA
    just buy one, money well spent.
    Sleeper CP
    Damn Sleeper, thanks to you guys, I've been pullin the trigger so much lately it sounds like an Uzi going off around here.
    The crank trigger/MSD 7 is next on the list, as long as I come home from B-field with everything in one piece
    Senior Member wajetboy's Avatar
    Auburn, WA
    looks like i will be getting one also chris, timing is jumping from 34 to 25 above 3500. i dont like this and also wonder what kind of power that may be costing me. and i only said i was going to do a couple things on the boat this winter oops, that was just to keep the woman happy
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    waterloo
    First crank trigger I ran on the dyno was an old MSD magnetic pickup with the steel inserts in the aluminum wheel. That was what 20 years ago or more. When I saw how stable the timing was, I knew it was the way to go. Never looked back for recommending, or running personally.
    If you are not fully impressed....well...you just don't like cool. LOL
    Wags
    OK, with that being said, depending upon appliication, you may have to make a spacer or two to change alignment of stuff. I consider thhis normal. Blower applications are no big deal either. Two thumbs up.
    Enumclaw, WA
    Alrighty, looks like yet another thing on the list . Thanks for the input guys !!!
    Austin; sounds like that'll add stability to yours, and some ponies
    Auburn, WA
    i was doing a little reading and it sounds like i can use my old disy as long as it is locked out which it is. is this correct?
    Quote Originally Posted by wajetboy View Post
    Exactly.
    It needs to be in good working order and it sounds like the shaft is likely loose in yours.
    Cantard 71hallett's Avatar
    snow bank
    Wonder if I could use the signal of one to run my tack?
    your ignition box should provide the tach signal
    #55
    snow bank
    Mag........ and every contraption I bought doesnt work right. Going to have to buy that $500 tack I guess.
