Leak Down %
Results 1 to 8 of 8
Leak Down %
    Senior Member BLOWN HOWARD's Avatar
    Default Leak Down %
    Had my buddy do a leak down and all cylinders are at 20% when is it time for a rebuild. At what percentage do you say time for a rebuild
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    An engine in great condition should generally show only 5 to 10% leakage. An engine that’s still in pretty good condition may show up to 20% leakage. But more than 30% leakage indicates trouble.
    Quote Originally Posted by 500BBC View Post
    especially if he's using rings with big gaps. i've got a pretty good size gap on top and bottom, i leaked 10% at 3hrs on the motor, and after about 30hrs, its down to 8%. the rings broke in and sealed up alil more over time. still have 240psi cranking compression across the cylinders, and i've put alot of nitrous thru it.
    Shoot then its good to go!!!!!!!!!!!! I only put maybe 5-10hrs a yr on it so its probably good for a few more years.
    Tested warm or cold? How long has it been sitting since it was last run?
    The 20% Was Tested Cold. I Run It About 3 Times A Yr
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Blown Howard,
    When you notice there is a lot of blow by, that tells you something is in need of repair too.
    On my engine, when I get blow by coming out the breathers, I've melted something.
    Senior Member Havasu Carrera's Avatar
    Hey Crazy Hippy! Did you used to have a STV? U used to frequent the delta? CA?
