blown 496
Results 1 to 12 of 12
blown 496
    Default blown 496
    running a 496 with a 8-71 intercooled,and two 850 demon blower carbs. will i make more hp with a 10-71 with my 850 carbs?
    Kingman/Golden Vly, Az
    Quote Originally Posted by 94 tpr View Post
    IMHO, i think the set-up u have is just fine ...the 10-71 is a "whole" lot of blower for that c.i.
    i would tune the chit out of it & go have fun...just my .02 cents
    FastRat
    Senior Member Hydroguy's Avatar
    You won't have to turn the blower as hard to make the same boost.
    Quote Originally Posted by Hydroguy View Post
    ...but it will take more power to turn the 1071 than the 871...
    JMO
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    up the overdrive on your 8? Go another 5%
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Default pump gas
    on pump gas. how much boost could i get away with on av gas?
    AZ, Queen Creek
    Say 5 to 7 lbs to play it safe
    ___________
    Not sure of your static compression. but just a point of reference. My motors are from Merc racing, they are 502ci, 7.5-1 CR, 420 Mega blowers( about the same size as your 871), with big intercoolers. They run 10psi at full boost and run on 91 octane. With the motor set up right, you have a lot of hp still sitting on the table.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Default av
    how much boost on av gas could i get away with.
    AZ, Queen Creek
    Depends on compression. To say the least gas is actually more powerful than alcohol. The window of burning up a motor on alcohol as compared to blown gas, alcohol can be out of tune more than gas and not gernade the motor.
    I'd say NO more than 7
    Be in the 5-7 range
    3-4 if you run it wide open alot.
    ___________
    Default compression
    8 in a half to 1
    AZ, Queen Creek
    Thumbs up
    5-7 would be optimal
    ___________
