Blower basics
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 53
Blower basics
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Blower basics
    Hey, just trying to learn a little bit about these "huffer" motors you guys run ! So my first question is if somebody is running a 468ci w/ a 671 blower 21% over what the hell does that mean as far as compression/power. Is this another term for "boost" ??? Is this thing hauling the mail or is this mild ? Edjimacate me
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    Quote Originally Posted by 76Miller View Post
    First off, a 468 with a 6-71 is kid sh!t, J/K. Boost is the amount of air forced in when vaccume no longer exists. 21% would be the % over 1to1.
    It's not that i don't care, I just dont give a sh!t!
    Quote Originally Posted by vee-driven View Post
    Ok so when you turn up the boost that is going to make that ratio (21%) increase ? Also, adding more boost to a motor is just a pulley swap, right ?
    Lomita so. cal.
    You got it! I can run race gas on 15lbs or flip it to 6lbs and run pump.
    Last questions on this subject.....is there some kind of formula/breakdown to figure how much boost a motor is running if its 21% w/ a 671 ? Also what do you think a little 468ci w/ this set up is making hp wise ????
    Cantard 71hallett's Avatar
    snow bank
    What,s a 6-71?
    As you add boost you also treat it like any power adder, things like timing exc.
    snow bank
    Would need info like what heads you are using.
    Lomita so. cal.
    Run it with a boost gauge to see what the # is, all engines vary.
    I think BDS has a chart on their site with the #'s your looking for.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    surprised noone has mentioned how hot the intake charge would be at 21% on a unintercooled 6-71. i ran a weiand 6-71 on my 475bbc last summer and there was no noticeable difference between 12% and 21%imo. i was taking out so much timing to keep from detonating the hot intake charge, that imo , it wasn't worth over driving that much unless i had a badass chiller. you start needing to run 21%, than its time for a 8-71
    I haven't even seen the motor I'm referring to yet. I'm going off what the guy said. I'm so used to talking about n/a motors that I was a little lost w/ the terminology. I motor has a intercooler on it though.
    ported 990's, not sure about anything it has ( c/r, cam specs, etc)
    Quote Originally Posted by DMOORE View Post
    Darrell.
    Cool, I'll check it out. Thanks
    Pat, where did you meet that chick in your avatar ? Sully's...dollar beers ? Thanks for the info.
