E-85
Results 1 to 14 of 24
E-85
    Senior Member nos1967's Avatar
    Default E-85
    sense E-85 gas is higher octane, 100+ i think? With an E-85 tuned carburetor would you be able to run higher compression? like 11-1 or 12-1 with aluminum heads, without detonation? and sense it is high octane why arnt we taking advantage of the fact that its cheaper and we can run it in high compression motors?
    ptz
    ptz is offline
    so ca
    Wink
    old dogs are afraid of new tricks ?
    if you can run more comp... you will make more hp...
    availability is the key factor..
    it isn't everywhere it should be.
    MI
    I like the stuff.
    Hondo Jet blown540's Avatar
    Holland, Mi
    Not only can you, but you should run higher compression ratios with e85 for greater efficiency. I've heard of people running as high as 16-1 with the stuff! I'm excited to try it, I just got my carbs back last week. I have a station that sells e85 three blocks away. So I,m taking advantage of that
    MI
    Who did your Carbs for you?
    There's already quite a bit of e85 info here if you do a thread search. For me it's hard to out weigh the extra 1/3 fuel useage , and the lack of avalibilty. I just kissed race gas good bye and it feels good. 1 year from now I could be singing a different story...
    Holland, Mi
    Quote Originally Posted by sanger rat View Post
    I ended up going with quick fuel, believe it or not they gave me the best deal.
    Holland, Mi
    I like the stuff.
    .........Wow, that thing's off the hook!
    Ada, Michigan
    I've been running E 85 all summer now.
    It's been a great fuel. I run 21# of turbo boost with it.
    Last time I filled up E85 was $3.25 / gal. and 110 octane race gas is at
    $6./gallon.
    E 85 smells a lot better too.
    http://www.kevinkernen.com/68.MOV
    Derby, Kansas
    Quote Originally Posted by ptz View Post
    I've done quite a bit of research on it but what it comes down to for me is the availability issue and the conversion costs. After converting my carbs and fuel system to run E-85 it will take about 3 years for me to break even when compared to av-gas. I do know several people in my area running it with cars in boost applications supercharged and turbo and they love it. If you need to buy a carb or if your setting up a new injection system I'd really take a look at it. My engine is 12.5:1 and detonation was not one of my concerns running E-85.
    Derby, Kansas
    $6./gallon.
    The guy in your video clip just damn near lost that flat!!!!!
    Thats a v-drive 21 Daytona tunnel in the video
    Derby, Kansas
    Not Marks boat this one http://www.kevinkernen.com
    Hey now it's early but I do know the difference between a flat and a 21' tunnel.
    i'd be runnin the stuff if i knew my supply was there for good, but nada. my fuel system is methanol compatable, all i've gotta do is change meter plates and dick with the bleeds some if i switch. i'm ready for it, just don't see a pump popping up in lil ole hugo okla. though
