Aluminum standoffs source
Results 1 to 5 of 5
    WV
    Default Aluminum standoffs source
    Anyone have a good source for round aluminum standoffs, either 3/8 or 1/2 inch ID for spacing the bolt on stuff on front of motor?
    Surprise, AZ
    Yeah, buy some round stock and drill a hole in it with your drill press.
    Senior Member bp298's Avatar
    LHC
    Aluminum Round Rods | MSCDirect.com
    get the size you want, cut it, face it, drill it. piece o cake.
    Senior Member Sharkbit's Avatar
    Jan 2010
    San Francisco Bay Area
    Cool
    Quote Originally Posted by Jspeeddemon View Post
    I have some USA Kaiser aluminum rod, 6061-T6511, 2-inch diameter, 4-inch lengths, 18 pcs. I was going to change valve angles in a pair of heads but went with a different approach. You can make these whatever OD and ID you might need for your app. Offered at $4 each which is about $3 per pound (compare to $8 for the same 4-in length in one of the links above and you need to buy a foot at a time). Call if interested,
    LO
    High Flow Dynamics
