Valve lash recommendation
Results 1 to 8 of 8
    Sep 2012
    Default Valve lash recommendation
    Hi,
    I have an engine which I Purchased and never got cam specs or card with.
    It has been running very well but time to check the rockers and I am not exactly sure what to set the lash at, Without going to the lengths of pulling the cam and finding out specs.
    Currently I have some up and down readings but 5 cyl are reading .20 and 3cyl at .18 cold, What would be a setting on the safe side all .18 or .20. open spring pressure is 598lbs, Crower enduro rockers 1.6 intake, 1.52 exhaust. Any thoughts?
    Quote Originally Posted by Caribbean17 View Post
    Hi,
    Tighter is safer.
    Jan 2011
    Mickleton, New Jersey
    Hi,
    I don't think you mean .20 or .18 maybe set them at .019
    Sep 2012
    Yes sorry missed a zero in there .018- .020
    Default Top/bottom...?
    Old school rule, "tighter is better up top, loose is better down low".... A heavy load from a standing start likes 'um looser, to wind it tight up top, tighter... The difference means very little to "lift", but you can add/subtract a little duration...
    Ray
    LOUD BOATS SAVE LIVES
    Ray
    You can also destroy lifters in a heartbeat with them too loose. Specially a tight lash roller. Many of the old flat tappet games don't go over well with some rollers.
    OP...in your case either .018 or .020 will be safe. If you have aluminum heads you can add .006" and that will be your hot lash, so you're looking at .024 - .026 hot but given the choice between the two I'd start with the tighter.
    Default Limits...
    Of course Bob... There are limits in both directions, and anything tighter than what he had should also dictate a P/V check through the overlap sequence... A few added degrees on a steep ramp may get undesirable results...
    Ray
