It"s a labor of love!
    Senior Member mustangmark's Avatar
    Nov 2009
    california
    Default It"s a labor of love!
    I don't post on here to often but thought I'd give an update of what I did to my Warlock this past winter. I ended up spending the entire winter and more money than expected but it turned out real nice and I'm happy with how it ran. In the end of 2011 I dropped a valve in the 454 I was running during a DLB event and spent the winter of 2012 building a 502 with a b&m 250 blower on it. The motor is bored 60 over which makes it 516cu in. It has oliver rods, srp pistons, a custom ground hyd. roller cam from Bob Mardera, morel lifters, grumpy jenkins heads that are fully ported, msd ignition, a dan olson oil pan, etc..... It turned out to be a pretty nice motor all and all.
    This past winter it got a bit out of hand and by the beginning of the summer I had changed from the b&m 250 blower to an M3 procharger with an intercooler, new fuel system (areomotive pump, fuel filter and regulator, -10 feed line with a -8 return, c&s blow through carb, brodix intake,etc...), full hyd. steering, eddie marine kplanes, a bblades bravo 1 26p prop, all new autometer gauges with a gps speedo, thru transom pick up for the motor and used the origional pick up to feed the intercooler, lots of custom made brackets, etc.......and hours and hours of work!
    Here's some pics of it....hope you guys enjoy!
Name:	2013 upgrades3.jpg
ID:	410281   Click image for larger version.
Name:	2013 upgrades4.jpg
ID:	410289   Click image for larger version.
Name:	2013 upgrades14.jpg
ID:	410297   Click image for larger version.
Name:	2013 upgrades17.jpg
ID:	410305   Click image for larger version.
Name:	2013 upgrades13.jpg
Name:	2013 upgrades9.jpg
ID:	410329   Click image for larger version.
Name:	2013 upgrades11.jpg
ID:	410337   Click image for larger version.
Name:	2013 upgrades15.jpg
ID:	410345   Click image for larger version.
Name:	2013 upgrades16.jpg
    Somewhere between Paso & L.A.
    Well how doe's it run? Prop seems kinda on the small side
    Nov 2009
    california
    Quote Originally Posted by Blowncat 509 View Post
    It's in an 89 Warlock Euro24. Best I got out of it was 85mph on gps this summer.That was with a non labbed bravo 1 28p that I put on it around mid season. I'm going to send the prop to bblades this winter and let them do their "magic" to it. At 85mph I was seeing 5,500rpm. I'm also considering upping the boost from 6psi to 8psi. It pulls pretty hard in the mid and top end right now.
    Senior Member ICDEDPPL's Avatar
    Oct 2013
    Thumbs up
    Nice work!
