Crack in head
Results 1 to 13 of 13
Crack in head
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default Crack in head
    Any ideas on what would cause a crack in the intake port? Casting issue? These have been ported
    d
    Jun 2010
    Crap aluminum- forging and machining
    Senior Member Tinkerer's Avatar
    Jan 2010
    aluminum head - grind it a little further, weld it up and smooth it off - good as new.
    Cast iron - start over with a new head.
    Placentia, CA
    Pro Crap head?
    steveo143 AKA DiMarco 21 II
    Seen a crack in the same area before on some 990's that had been slightly ported.had a weird misfire that was tough to figure out till we saw water on a plug.must be a thin area to the coolant passage wether its alum or cast.btw congrats on the newborn led! Hope mom and baby are doin well.
    Chantilly Va.
    I have seen an intake port crack due to a rocker stud being flexed. I noticed a slight misfire at idle, pulled rocker cover to discover crack. These heads were old O.E. Chevy aluminum castings, heavily ported. This was years ago bracket racing.I dont know if this helps or not, just experience.
    El Cajon, Ca.
    Thin casting... or rather, thin in that area... whether it be from a bit heavy on the porting, thin (overall) casting to begin with, or core shift.
    Seen procomp heads bust the rocker studs right off taking a chunk of the intake port roof with it... also seen the spring area cut deeper and had it start cracking there.
    The Bostick®
    Led
    Led is offline
    Jul 2010
    Trick Flow 320 aluminum heads, I like them, flow good, plan is to grind out the crack and weld up them smooth, guessing thin casting, seems to be water on the other side, no signs on water in the cylinder, with an open water system with hardly any pressure and 7lbs of boost may have kept the water out, pulled heads for exhaust valve issue and found this during reassembly, just puzzling and financially scary,
    Thanks Impatient family doing great!
    Led
    Led is offline
    Jul 2010
    I wouldn't have a set of Pro Comps even set in the floor in shop, but they can be okay with good hardware, I would rather put good hardware on decent castings, as I did, these trick flows are not top of the line, but I think (as of today) they are up to the job for me, one more set back and I will go another route
    There is a usually a paste ooze part line in some heads in that area. Little too much paste when assembling the cores and you get a line of thin area.
    You could be the lucky individual that got one.
    Senior Member Bruise Brothers Dad's Avatar
    Pomona,Ca
    There used to be a fella here in So Cal that could get great numbers out of any head, you just couldn't put water to them. More than likely they are just a bit thin, have seen this more times than not. When people had me weld a pin hole and I had to put a spot the size of a silver dollar, had to explain that I need material that is at least .080 to get the leak stopped. This is just one of the many problems that could be causing your problem.....BBD
    Need help finding this 1973 Sanger 18'6" bubble deck mahogany bottom and stringers I was living in Pomona when I sold her in 1979. Just wonder if she still exists
    Update Found my old Sanger 12/7/14 in Reno.
    Led
    Led is offline
    Jul 2010
    Thanks for the info, be anxious to see the repair, probably be better than new, Atleast I hope
    Dec 2010
    Sapulpa ok
    Have Don's neighbor Repair it. He's good....
