Gasket matching?
Gasket matching?
    Senior Member johnf's Avatar
    Oct 2012
    Default Gasket matching?
    First timer here. Before I ruin my new manifold. If I remove the material were marked will this be ok? Also do you trim off gasket that will be in the valley? ( If it's the right gasket going the right way?) Trying a rebuild and want to get all the grinding done. Thanks for any help. Johnf
Name:	fuck 125 (1280x960).jpg
ID:	415673   Click image for larger version.
Name:	fuck 126 (1280x960).jpg
ID:	415681   Click image for larger version.
Name:	fuck 127 (1280x960).jpg
ID:	415689   Click image for larger version.
Name:	fuck 128 (1280x960).jpg
ID:	415697   Click image for larger version.
Name:	fuck 129 (1280x960).jpg
Name:	fuck 130 (1280x960).jpg
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Steelcomp should along shortly to help ya ...
    If there is any gasket hanging in the port, trim it away. Other wise just install it. Grinding the manifold is a waste of your time, unless you have else to do. Like putting it back together.
    Oct 2012
    Thank you BOB, That was alot easier than getting rid of the bumps on the exhaust! Another chore off the list.
