2 Bolt vs 4 Bolt
Results 1 to 14 of 38
2 Bolt vs 4 Bolt
    Kingman/Golden Vly, Az
    Default 2 Bolt vs 4 Bolt
    we all know a 4 bolt main set-up is the best, BUT, will a 2 bolt main set-up work with a low HP application?...say 375-400HP...how much RPM will they handle?
    how many of you are running 2 bolt main motors & what kind of RPM's are you turning?
    FastRat
    Hondo Jet blown540's Avatar
    Holland, Mi
    I believe a cast crank 2-bolt combo is good for up to [email protected] beyond that cap walk becomes a problem and it's bye bye bearings. My old motor was a cast crank 2-bolt in the 500hp area. I beat the hell out of it (over revved it, over heated the oil) but when I tore it down the bearing were still good! These are stout motors, they will take 400hp for years trouble free
    Newton Ks.
    I run over 600 from my 2-bolt, cast cranked, nitrous snorting, 30 year old 454, it's fine.
    Keep the cast cranks under 6,000RPM and a good balancer on them.
    Make yourself sleep a little easier with a set of ARP main studs in it, beefs it up a bit, and not terribly expensive.
    I run a max of 5400 most of the time, untill toggling in the nitrous.
    H.L. Mencken
    I'm running estimated [email protected] on a 2 bolt main. I did put the ARP main studs in though for some added strength. But I'm running OEM cast crank and stock rods with forged pistons at 9.5:1 compression. Been beatin' the hell out of it this season...unloaded the pump several times on it. I do have a rev limiter set to 6000RPM, which IMO every jet boat should have a rev limiter. But as has already been stated above keep it under 6000 RPM and she'll perform like a champ for years to come.
    Just my $0.02.
    Cantard 71hallett's Avatar
    snow bank
    Word is that a studded 2 bolt is as strong as a stock 4 bolt. You have nothing to worry about. My old 496 was a studded 2 bolt and it made 700hp and I turned it 6800 with absolutley no problems. Still running strong today, 7 years later.
    snow bank
    Hey Blown540, What heads are those?
    my 327 ran for 40 years without having to tear apart any part of the block EVER. 2 bolt main. ended up rebuilding it because of loss of power...which was to due the valve seats being very pitted from todays gas. but the bearings looked perfect, pretty amazing if you ask me.
    Holland, Mi
    Slightly ported Dart 360's
    snow bank
    Looks good. Now you just need to cut the seats back. J/K
    Choking my ....... beerjet's Avatar
    Rancho Cucamonga
    I've been flat footing a 425 HP at 5k -52000 at the circle races for a couple of years now . This motor was old when I bought it and it's all stock shit inside . 600 ponies sounds about right for a safe cieling .
    Just remember...if you switch to studs, have your main bores checked. The're probably not going to be round any more.
    Silverdale, Washington
    Hey Scott, based on your experiance has the switch to studs on a 2-bolter significantly changed things so you have to take a significant amount of metal out to get them round again or does it "typically" take just a touch up like a light line-hone??
    The Right Coast/SE-PA
    Word is that a studded 2 bolt is as strong as a stock 4 bolt..../
    Uh, where did you hear that?
    I was told (local engine shop) even a "studded" 2-bolt could walk the caps in a 650 HP application.
    I read somewhere on here, that boats are a lil different than cars in this area, in that there not getting shock loaded, like dropping the clutch in a car.
