850/900 hp
Results 1 to 14 of 31
850/900 hp
    Senior Member Tinkerer's Avatar
    Jan 2010
    Default 850/900 hp
    I am at the design stage of building a new engine for the Daytona.
    What would your build consist of. Money is an issue but do want good parts but not overkill. I will assemble the engine myself after all of the machining is done by a local shop I have used for over 20 years. I have built performance engines for 35 years.
    It will be natural aspirated, roller cam, tunnel ram? F.A.S.T.
    electronic fuel injection.
    What cubes - 598 or 632?
    Plan on using a tall deck block.
    I have dry exhaust so cam overlap is not an issue.
    Would you do the firing order swap?
    Steve
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Quote Originally Posted by Tinkerer View Post
    Steve
    sounds like your the man.....35 years building performance engines.....I say go big.....or just go home.....
    I’d rather live with a good question than a bad answer.
    Sacramento area
    E85x14.5:1x632cid=922hp
    Should be pretty easy. Thats at 1.46 hp per ci, not too hard to do.
    Be safe, schick
    Jan 2010
    You Know I was thinking about E85.
    Is this a jet or IO? If it's a jet, 565 or 588 with a tunnel ram and hyd. roller should make 900hp easy on pump gas ~ 6500 rpm.
    WV
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Or this and it's for sale
    This is gonna be awesome
    Senior Member Nosjunkie's Avatar
    May 2010
    Rough and Ready CA.
    Quote Originally Posted by Hullshot View Post
    This is a nice setup.. I was eyeing it when I was there...
    LIVE FREE OR DIE
    Yes. BIG as you can go. And yes. Firing order swap or get with Straub and try a two pattern.
    Apr 2010
    Rocklin, Calif.
    When Chris did my cam, I asked about the 4-7 swap..he didnt think it would be right for me....and what is a two pattern?
    This could get interesting.
    How did I know you were sitting in a dark corner waiting to pounce?
    ME??
    I just trying to figure out what you call 90+% of the cams out there for BBC that have different lobes for intake and exhaust? Aren't those dual pattern or "two" pattern cams?
    Or did you mean something different?
