cam advice.. will this be ok with water log exhaust
Results 1 to 9 of 9
    Senior Member Sharkbit's Avatar
    Jan 2010
    Default cam advice.. will this be ok with water log exhaust
    I can get a deal on this cam.
    http://www.summitracing.com/parts/cc...make/chevrolet
    Was gonna run it in my daycruiser, will there any issues with water logs and reversion???
    yes it would work. Cruiser a Jet or what? That could make a difference. Would not use it in a I/O.
    Rancho Cordova. CA
    I believe that cam is not log friendly. You will most likely get some water reversion.
    Logs are more forgiving about overlap than riser type manifolds?
    Jan 2010
    Sorry, yes its a jet with hardin logs. Just freshening up the ol cruiser this winter as shes getting tired and been neglected since all my money been going to the drag boat.
    I was concerned with idle quality. I/O's don't like to be put into gear at 1100 rpm. And the cam is at the max on its size. My opinion of course. Just keep the water out of it till 2500-3000 rpm. Now beat away.
    Logs aren't like wet Bassetts. You never shut the water off to them.
    If the outlets are below the water line, or he is running snails, that cam could be problematic.
    Over the transoms with the entering the over the transom pipes towards the end, it would probably be ok.
    Jan 2010
    The outlets are under water. I appreciate the input guys. I think I will go back to plan a which is a much smaller flat tappet.
    Jan 2010
    And has snails.
