Lucas Red & Tacky for Wheel Bearings?
Results 1 to 14 of 14
    The Right Coast/SE-PA
    Default Lucas Red & Tacky for Wheel Bearings?
    Seriously, is this grease ok for Hi-Temp disc brake wheel bearings, or more suited for ball joints?
    I sure hope so, all my bearings are packed in the stuff.
    Mar 2010
    Clarksville, TN
    That's what I use, no problems so far
    Nechako
    you asked about "Hi-Temp" disc brakes so wondering if this might be for your vette ? red and tacky good stuff in the boat trailer hubs and ball joints , think I look for something a little lighter if it's for the vette
    Close to the water...
    I buy it by the case for lubing, heavy equipment and drive lines
    High temp wheel bearing grease is a little different blend.
    Marine grease is a special blend also.
    Quote Originally Posted by Canuc View Post
    actually yes for the Vette...When I first started using Red & Tacky I thought it was just that. But now it seems thin and the oil will run out of it quite easily.
    A grease called Mystic G-6 EP2 at Walmart is gettig good reviews...and it's inexpensive too.
    I believe it JT6. All Mytic greases are JT6.
    Mystic is the shiznit. Their multi purpose #2 grease makes anything Lucas makes look down right water soluble.
    You don't want their EP for disc brakes. Their plain Hi temp #2 is what you want.
    If you find a GOOD quality grease that isn't expensive, let me know.
    Nechako
    the lucas seems to have lots of oil in it which i think is good for wheel bearings . just not sure if that tacky stuff is the best for a hi-speed app. like a vette , but probably be fine . a grade 1.5 synthetic blend that's not so tacky might be better .
    Good to know mystic is good stuff .pretty easy to get around here and cheaper than red n tacky.the county guys use mystic oil and grease on their stuff and seem to like it but ive never tried it.
    Yeah the farm guys love the stuff.
    Another very good water resistant grease is Millitec 1 Not cheap at 12.00 a tube, but its great stuff.
    Have seen failures with mystic in jet pump thrust bearings. Don't know which Mystic but do know it was mystic. Seems to wash out really easy.
    Got me some Mystik® JT-6® Hi-Temp Grease #2
    Thumbs up
    Quote Originally Posted by tigertooth View Post
    Also good to know!
    Not really valid...
    being you didn't know what grease you used. Any product used improperly or not as specified may cause failures.
    I just read an in depth review how Mystik® JT-6® Hi-Temp Grease #2 resists wash-out better then many tested 'marine' specific greases yet, it also has the hi-temp usage for disc brake bearings...seems to be the best for both worlds?
    I've been reading some truly good things about Mystic Hi-Temp Grease #2 > but one odd thing, it does have a lower 'drop point' vs the Lucas Red & Tacky being 540
    Sometimes the more I research a product the more I chase my own tail, key word being >"sometimes"
