Gen V timing cover Two piece?
Results 1 to 14 of 15
    Default Gen V timing cover Two piece?
    Gen V BBC two piece timing cover, Who carries them and who makes them? Thanks in advance Sleek
    Kingman/Golden Vly, Az
    i believe Summitt & Jeg's carry them...ck there web sites!
    FastRat
    #55
    I'm looking for one that will allow access to the cam, a two piece, easy to find for the gen IV and VI, but no luck with the gen V.
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    I have a couple I can get from Comp that are 2 piece and 3 piece for your motor. Let me know if I can help.
    CP Performance
    www.cpperformance.com
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    Senior Member VAMI's Avatar
    srq,florida
    Gen 4 and 5 will cross and fit both blocks. gen 6 has 6 bolts and only fits that.
    Woodstock, IL.
    Quote Originally Posted by VAMI View Post
    X2
    Why is it then Gen V timing cover, and gasket, are different part numbers, than Gen IV. Every where I look I see this, what are the differences?
    srq,florida
    I think the gen 5 cover is oringed as the gen 4 is a gasket, but both have the same bolt pattern.
    FAT GUY IN A TPR STEALTH NO REGRET$'s Avatar
    MENIFEE . CA
    THE FRONT OF A GEN 4 IS DIFFERENT THAN A 5 ON THE PAN... ONE IS WIDE AND FLAT THE OTHER IS THIN AND INSERTS ,, SAME BOLT PATTERN DIFFERENT PAN SEALING AREA...
    "Life's tough......It's even tougher if you're stupid."
    -John Wayne
    ..JUST HAVING FUN..
    . . . .SIPPY CUP RACING. . . .
    MySpace URL:
    http://www.myspace.com/dp734taj
    Quote Originally Posted by NO REGRET$ View Post
    So this is telling me it will not cross over Correct?
    Tri-Cities, TN
    Correct totally different seal radius. Mark 4 is its own animal. A Gen 5/6 share the same seal raduis but the design of the covers is different.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Tri-Cities, TN
    Correct. I believe Eddie marine or one of the others does make a 2 piece cover in aluminum but it will be pricey.
    Chris Straub
    Straub Technologies
    it's a boat, we don't use words like pricey, spendy etc. if you can still walk after paying for it, the price was REASONABLE
