Turbo motor w/bravo style outdrive?
Results 1 to 8 of 8
    Senior Member HighVoltage329's Avatar
    San Jose, Ca.
    Default Turbo motor w/bravo style outdrive?
    I thinking of putting a carb Gentry turbo set-up on my Hallett 240. I've got an Imco SC drive with hydraulic steering to the helm. My question is out of the hole performance. My low compression 502 with Merlin oval port heads pulls good from the bottom but I want more on the top. If I bolt the Gentry set up on this motor will I loose much on the bottom end? I know with a transmission in second gear to get the revs up they do fine but I won't have that. Anyone done it?
    Senior Member jstnoc's Avatar
    Riverside
    Im doing a similar setup in my 22 schiada. 509CI with gentry turbo setup sterndrive
    had schiada tt with stern drive.was not the fastest out of the hole,but was never mashing it due to fear of breaking drive.
    Quote Originally Posted by HighVoltage329 View Post
    Bob
    If you bolt the Gentry kit straight onto your existing engine, why would you suspect the bottom end performance would drop? With waste gates you should make boost and more power, right?
    San Jose, Ca.
    Bob
    Barry, I hoped you might see this. I thought maby since the carbs were going to be father from the intake I might loose some response on the bottom. Also do you think a low hour 502 bottom end would be up to the task for low boost?
    Sure, depending on how much boost you intend to run.
    Maybe PM me for my phone number if you like and we can discuss what you want to do.
    San Jose, Ca.
    Quote Originally Posted by jstnoc View Post
    Looks like you will be making some exhaust changes also. That's part of the cost equation that I'm working on now. I hope to retrofit some Stellings tail pipes that I got cheep to go from the turbos out the transom.
    San Jose, Ca.
    Quote Originally Posted by 86rayson View Post
    I just need enough to pull a skier out but also may need a bigger prop for the top end.
