Plugs?
Results 1 to 10 of 10
Plugs?
    Senior Member Kylemenz1's Avatar
    Carlsbad
    Default Plugs?
    I know I have seen it on here before but can't seem to find where. What plugs are you guys running? I seem to remember a #8 NKG but don't remember the model #. I have a 525sc with a Holley Mega Blower running 9lbs of boost.
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Are you running a mag or a 6al msd system?
    Carlsbad
    Guess that would be some good info.
    MSD Marine 6M-2L, Blaster coil, and Marine distributor.
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default NGK Spark Plugs
    Ngk - R5671A-7, 8, 9, 10
    Start with the 9 and 10 is a colder plug
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by willis View Post
    You got it willis!
    Thats what I run, I wonder if he was thinking of B8ES seems like the are about the same deal,I dunno. Btw does running a blower change anything -plug related? I was a little suprised to see you sugesting the same plugs I run,N/A.
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    NGK's are great plugs.
    A couple of links to get the right plug for your heads.
    http://www.kaila.net/tl125/tl125ngkcode.html
    http://www.ngk.com/search_char.asp?s...anufacturerID=
    Senior Member cave's Avatar
    Mesa, AZ
    Ha ha I use B8es in my Quads. That would be killer if I could run them in the blower motor..
    Takin it home
    A few months ago when I picked up an hei, I got a hold of brodix to ask what plug to uses, and I'm pretty sure b8es is one of the plugs they said would be a good starting point. I dunno, maybe I'm up in the night again,lol It's also the plug I ran in my yz490.
