Cam and lifter question.
Results 1 to 8 of 8
    Senior Member schiada flatty's Avatar
    Lloydminster Canada
    Default Cam and lifter question.
    I was wondering if you always have to install new lifters with a new cam? I'm running a solid roller and someone told me you can get away with it on a roller if there in good shape.
    At $100/ hp plus injection oil it's just to expensive to go that slow!
    Quote Originally Posted by schiada flatty View Post
    Roller lifters and roller cams are pretty much interchangeable if everything is in good condition. Make sure your springs are in good condition too.
    Not only do they need to be in good shape like Steel mentioned, but they need to be the RIGHT spring for the new cam. More roller lifters are destroyed due to weak or springs that have to low seat pressure as well as the too light spring rate than anything else.
    Find out what seat pressure, and rate or open pressure the cam needs and have yours checked, or get the right springs to start with.
    Lloydminster Canada
    Thanks for the info, I wasn't sure. And I'm glad cause roller lifters are'nt cheap. Ill have my springs checked for the extra lift with the new cam.
    If you don't know the history or age of the lifters, it might be worth spending the money to replace them. I am in the middle of rebuilding a turbo engine that someone else rebuilt with used roller lifters,, lasted 4 hours. The needle bearings and pieces of the lifter (that were obviously below the valley screens) made enough of a mess the bottom end and cost an awful lot of money.
    Lloydminster Canada
    Thanks for the info. Ill have mine checked or buy new springs. Haven't got any idea when the last time the heads had any work on them. I got to take it apart in a couple weeks. I'm a body man that usually horse trade with my journeyman mechanics friends. When it comes to my engines.
    Would this cam be a good choice for a 10:1 comp 427 with 990 heads?
    11-706-9 - Marineâ„¢ Mechanical Roller Camshafts
    Oct 2011
    Sandia,Tx. 78383
    best money spent on a cam would be from C.Straub here on the forums , have a couple friends who got custom cams from him and they are Extremely Happy cams out of a catalog are a fix for a well its close enough one shoe fits all type deal , Chris can fab a cam to get maximum performance with what YOU have !
    http://oathkeepers.org
    Tri-Cities, TN
    If you need some help with the combo give us a shout.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
