Stud girdle ???
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 46
Stud girdle ???
    Sep 2012
    Default Stud girdle ???
    What is the best stud girdle for bbc gen 4, performer rpm #61459 alu, thanks I have the comp cam 1 piece, wanted to up grade. Thanks agian.
    Sep 2012
    Perfect, thank,s agian.
    The Jomar is nice girdle and may the way to go if you want to use your current adjusters and save a little money.
    Orlando.FL
    Be sure it is a good one and fits perfect or your going backwards. Not really necessary until a excess after 6000 rpm. So I been told.
    Sep 2012
    Do not plan on spinning past 6000, but it is a solid roller, it seem,s some say not needed?.
    Quote Originally Posted by Bobbylisa View Post
    I recommend a girdle with any solid roller, no matter how high you spin it. JMO, YMMV.
    Sep 2012
    Thank,s agian
    Oct 2011
    Sandia,Tx. 78383
    Jessel shafts are the best stud girdle
    http://oathkeepers.org
    Sep 2012
    lol
    Quote Originally Posted by Gopher711 View Post
    Pro series, yes. Sportsman, no.
    Chantilly Va.
    Default Stud Girdle...
    The OP says he has the Comp one-peice. Steel says he recommends a girdle if you run solid roller. Bobbylisa can you tell us what part no. you have that you want to upgrade ? And why ? Thanks for your time, Jack. Scott, what is ymmv ?
    Sep 2012
    The one piece fit,s nice, but it is a little work get it on-off, and a little extra work when checking valve lash, I have oil leaking past my guide seal,s so I was going to pull it down to look at some seal,s, (upgrade) get a good one that is not a one piece. That,s it, thank,s
