King rod bearing question
Results 1 to 8 of 8
    031 RIVER4FUN's Avatar
    Default King rod bearing question
    BB chevy, dart block, eagle crank & h beam rods. The King bearing I have always used, Part #0849l stdx with a chamfer. The replacements I got, part # CR808HPNSTDX don't have a chamfer and they are narrower by the width of the chamfer. Are these o.k to use? Sent an e-mail to King but I don't expect an answer 'cause of the Holidays
    They're fine. Most of the bearing companies have gone to the narrowed bearing instead of the chamfered. Its cheaper to make and works just as well
    Thanx Bob, that's what I thought
    This goes for all brands of bearing but I just had a set of kings in the shop and as a procedure all bearing are checked for oversize and one shell was not std as the rest there was a .010 in the box would have been caught also as we check every bearing bore size but just a reminder to all check everything. This was a rotation assy all new parts from a big vendor.
    Quote Originally Posted by havasubyou View Post
    That doesn't surprise me at all. I learned NOTHING surprises me anymore, specially bearings.
    Sad thing is ACL, which was one of the most consistent bearings out there, fell into financial trouble and was "sold" off. Hopefully the new owners keep the QC that ACL had. Time will tell. For right now, ACL's seem to be in short supply.
    This is a brand new out of the box Clevite.
Name:	clevite bearing.jpg
    The parts world is a scary place these days, double check everything. The pbm stuff better look at every valve lock you may get a std and a +or- in the same pkg. no longer use there valve train parts.
    There are some horror stories out there about PBM stuff. Mostly about valve train stuff, but certainly not limited to that. '
    Seen assembled PBM "brand" SBC head with 2 different locks on the same valve!!!!!
    Is it their supplier? Or is THEM? Who knows, But when they themselves do something like that, it raises concerns with me about the whole operation, regardless.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    I heard Morel supplied PBM with lifters? If Not.... I have PBM's trouble free so far
