Octane
Results 1 to 6 of 6
Octane
    Senior Member Big Otis's Avatar
    Default Octane
    So I Recently got the build specs on my motor. Compression is 7 to 1. 671 blower, 34 pulley top and bottom. (I do not have a boost gauge). I run race gas 110 octane. I think I'm wasting money on high-octane fuel. My question is will be okay running 91 octane?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You should be able to run 12 lbs of boost no problem on 91 octane.
    QE 439 Twin Turbo
    Senior Member Trigger's Avatar
    Aug 2011
    Lewisville, TX
    I have a comparable deal but never felt that I could go down on octane enough to make enough difference in price for the added piece of mind of just running what my builder told me to. I have heard mixed opinion about blending gasolines so I always shyed away from that too. I'm not an expert but I do think you're probably right about your situation. If it were me I would buy the same gas and spin the blower a little harder and make the extra power.
    You're way safe with 91. Like Info said, your reasonably safe up to 12 lbs even with iron heads and no intercooler. Assuming its a 454-468 you're making about 8 lbs at best.
    Question is, is it REALLY 7 to 1.
    Thanks, maybe I'll see if I can find a boost gauge to see what's going on.
