Pro comp ?
Results 1 to 14 of 41
Pro comp ?
    Bullhead city AZ
    Default Pro comp ?
    Ive been pricing parts for the build and i want to stud the top end.. Been looking at the ARP studs for $150 But i found Pro Comps for $75 Half the price and only 10 thousand psi less
    ARP's are rated @ 200,000
    Pro comps are @ 190,000
    Anybody use Pro Comp ?
    ARP's.......the country you save may be your own
    and i've seen the procomp studs also, their shitttt
    Tri-Cities, TN
    X 2
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Bullhead city AZ
    Thanks for the reply's.
    I guess the old saying is true..............You get what you pay for
    ARP's will be used
    Lurker
    NC
    Major fasteners (Heads, mains, rod bolts ect) are NO place to save money!!!!
    El Cajon, CA.
    I actually bought that ProComp set of head studs for my 427 Chevy, 4 of the studs didn't fit.
    I'm very happy with my Pro Comp aluminum heads, rocker arms, and stud girdles - except for the facts that their stud girdles don't fit their rocker arms without modifications and their push rod guide plates don't properly fit their heads.
    Bullhead city AZ
    Hey , you don't know till you ask someone who does know
    Tri-Cities, TN
    Just a couple of side notes. I own guideplate tooling and supply a few companies with BBC, SBC, and SBF plates. I have lost and gotten back a few custoemrs over the last few years because of failed guideplates. Chinese heat treat is hit and miss on these parts and I have had customers with failures on .15 BBC guideplates. Monitor these for excessive ware. The filings from these play havoc on bearings.
    Stud girdles. I make a 12 point polylock for stud girdles for the industry. In the last 8 or 9 years I have sold over 250K of these. I lost alot of biz due to the chinese girdles but in the last 18 months this business has picked back up do to the Chinese stuff pulling threads after one "valvetrain adjustment". The chinese BBC stud girdle kits come in the country with polylocks for about $24 a set. I can't make the polylocks for that but I will say my 12points will last more then one tightning.
    Chris Straub
    Straub Technologies
    the fix for procomp heads and the guide plate issue is to use dart adjustable guide plates
    Quote Originally Posted by 468Bahner View Post
    For what it's worth, with your mild, pump gas build, and your particular budget, I don't think you even need to consider running studs.
    Upland/Rancho
    PROCOMP = MAJOR JUNK
    Bullhead city AZ
    Barry,
    I agree with you, but you know Chevys are known for there stripped threads in the block, due to water and rust over a period of time. The block i have now has some Bitchen threads in it , and i probably dont need studs.
    But just to make life easier down the road or whatever, im gonna get me some
    Pw_Tony just had this issue, im sure he could explain it better
    Im anal and i want it perfect, even on my budget build
    I gotto do whatever it takes to get my boat in the water , ive got too many people on my back about it, and now is the time to show them i can do it
    Quote Originally Posted by PT PERF View Post
    if you have a problem with their products, i'd suggest you call them and voice your opinion or get the tech specs you may need
    i called the tech dept and met "jerry" a yr ago , now he owns a 7-11 down the block from my work still selling procomp stuff too in aisle 9 ,lol
