K&N question
Results 1 to 9 of 9
K&N question
    Senior Member customtouch's Avatar
    Nov 2008
    Austin Tx
    Default K&N question
    I know that K&N sells a CG approved Flame arrestor but is that filter actually any different than the standard one? There are no visible differences and they seem to be the same element so my I question is whether all the elements are constructed the same and will work in a closed engine compartment?
    I wondered the same thing when I purchased my K&N velocity stack/flame arrestor units. They list the same element as a replacement for both the marine applications and automotive usage however the lid on my units have the USCG approval stamped on the edge, nothing I could find on the elements. I paid the few dollars extra for the peace of mind should I ever be placed under a microscope by some over zealous and under informed LEO.
    I believe the flame arrestor law only applies to enclosed engines, and those below the level on the gunnels but I could be wrong.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Quote Originally Posted by customtouch View Post
    I know that K&N sells a CG approved spark arrestor but is that filter actually any different than the standard one? There are no visible differences and they seem to be the same element so my I question is whether all the elements are constructed the same and will work in a closed engine compartment?
    When was the last time you saw a SPARK come out of your carb? ITS A FLAME ARRESTOR
    As far as I can tell, there is no difference. However, its all in the labeling with some USCG approved stuff. Some starters are a perfect example.
    But if it isn't labeled as USCG, then you could have a problem with your insurance company in the event you need them.
    Yes, the K&N is suitable for closed engine compartments. There is no requirement for USCG approval with open engines.
    Nov 2008
    Austin Tx
    LOL!! Yea, it's an old habit. I was typing faster than I was thinking but you know what I meant!! I still say "Jetski" instead of PWC too if I don't catch myself first but people get the idea. I fixed it for ya so you would feel better.
    Thanks, I am am not concerned with insurance, only actual safety.
    Thanks for the answer since I use a K&N spark arrester.
    Lake Havasu az.
    I thought it didn't make any difference?I had a cop flip me guff over not having a marine MSD but then he tells me a non marine is ok as long as it's mounted higher than the gunnels
    Sep 2012
    I have a set they are stamped with the USCG logo on it , they do seem a little less pliable ( at the rubber area ) that is the only difference I noticed.
    Nov 2008
    Austin Tx
    FWIW, I called K&N directly and spoke to one of their tech guys. He told me that there is no real difference between the construction of the automotive filter and the USCG approved filter other than the stamp, which you might need to "prove" it passes if you get inspected. I am not concerned with that as long as it is safe so I will get the one I want. Thanks for the responses.
    Chantilly Va.
    Quote Originally Posted by Bobbylisa View Post
    I bought one that is marked "USCG APPROVED" also. It is stamped in the rubber.
