oval port and square port?
Results 1 to 9 of 9
    Member dirtslinger71's Avatar
    Dec 2013
    richmond va
    Default oval port and square port?
    I have a 461 BBC 11.5 to 1, 660 lift solid roller cam. This motor had stock casting 781 oval heads with stock sized valves topped with a wieand tunnel ram with two 660 carbs. I have just got a set of dart pro 1 aluminum 310 heads. My question is how bad is the oval port intake gonna hurt me on the square heads? Dart says to run it this way for torque but think Ima need the power up top.... any suggestions are welcome. Thanks
    ​"use it up,wear it out,make do or do without"
    Quote Originally Posted by dirtslinger71 View Post
    Run it, Just make sure the manifold seals at the top of the ports.
    I doubt you'll lose any power on top,
    run it, just make sure the manifold seals at the top of the ports.
    x2, 100%.
    Dec 2013
    richmond va
    Wow! Never would have figured that! So while I have your attention.... should I use a square gasket or oval gasket?
    You might have to try both and see which seals better.
    Like Steel posted, the gasket play no real role in the flow or power, only how well it seals.
    I have found most rectangle gaskets are pretty skimpy around the ports and the ovals sometimes don't seal well at the top. The top of most rectangle ports is higher than the ovals.
    Some ovals have more material above the port than others. Look for gaskets that aren't trimmed away above the port opening, like these Mr Gasket Ultra
    Avoid ones that are thin above the port like these Felpros. You can almost bet these won't seal a rectangle port head.
    Dec 2013
    richmond va
    Thanks guys y'all have been extremely helpful!
    Jan 2013
    dart recommends their oval single plane on rect. port heads in heavy car to get air speed up
    Thanks Bob...didn't really have time to go into detail.
