New GMPP 488 Crate Motor
Results 1 to 6 of 6
    New here Beer:30's Avatar
    Bakersfield, CA
    Default New GMPP 488 Crate Motor
    I haven't been able to copy the picture of it, but I'll keep looking. Might have to print the page, scan it in, and launder it that way. The valve covers it comes with has bosses for coil-per-cylinder
    The only main thing I see keeping it from being "better" is the hyper pistons. They did a forged crank and rods, but failed to follow through on the pistons. Weird.
    Vortec 8.0L
    19256938
    Part Number: 19256938
    Engine Type: Chevy Big-Block V-8
    Displacement (Litre): 8.0L
    Displacement (cu in): 488
    Bore x Stroke (in): 4.270x4.250
    Block (P/N 19256820): Tall Deck (10.2")
    Fuel Requirements: LPG/CNG
    Crankshaft (P/N 19300876): Forged steel
    Connecting Rods (P/N 19256831): Forged steel
    Firing Order: 1-8-7-2-6-5-4-3
    Connecting Rod Ratio: 1.58:1
    Pistons (19256829): Hypereutictic w/anodized top ring land
    Camshaft Type (P/N 12556291): Hydraulic Roller
    Cylinder Heads (P/N 19256827): Fast Burn Iron
    Damper (P/N 19256830) Cast Iron
    Valve Train: Fully Adjustable
    Compression Ratio: 9.9:1 nominal
    Crankcase capacity: 8 Qts
    Maximum Recommended rpm: 4,500
    Balanced: Internal
    315 HP @ 4500 rpm (CNG)
    375 HP @ 4200 rpm (gasoline)
    390 LB-FT @ 3500 rpm (CNG)
    475 LB-FT @ 3200 rpm (gasoline
    A Big-Block for your truck – and it’s
    compatible with gasoline, CNG, or LPG!
    When it comes to grunt work – like pulling your car hauler or offshore
    racing boat – Chevrolet Performance’s new, heavy-duty 8.0L Big-Block
    does the job like no other engine.
    This latest edition of the classic Big-Block is all about torque and makes
    up to 475 lb.-ft. (on gasoline) by only 3,200 rpm – and maintains a
    smooth, flat and useful torque band across the entire rpm range. That
    gives your truck the power to pull just about anything and flatten the
    steepest grades.
    The 8.0L is built with a tall-deck (10.2-inch deck height) version of our
    latest Big-Block casting, which features full-length water jackets, thicker
    main bearing webs and four-bolt main caps. It also uses a forged steel
    crankshaft and forged connecting rods for optimum strength. A long,
    4.250-inch stroke helps maximize the torque.
    This modern Big-Block is equipped for a crank-triggered ignition system
    and features a 4X camshaft and 58X crankshaft reluctor wheels to
    support it. The engine can support fuel injection and also has a provision
    for a mechanical fuel pump.* Our assembly comes with heads and a
    balancer installed. An induction system, ignition, starter, water pump
    and other accessories are required to finish the engine.
    NOTE: This engine requires an intake manifold designed for a tall-deck block.
    Chevrolet Performance intake manifold P/N 88961161 was used in development.
    Conventional big-block intake manifolds can be used with spacers (not included).
    *Production 8.0L camshaft does not have a fuel pump lobe.
    *Chevrolet Performance Crate Engines include a 24-month
    or 50,000-mile/80,000-kilometer limited warranty.
    Sale Price: $6,766.18
    List Price: $6,932.56
    The member 1bdhondo's Avatar
    ca
    Thats a nice motor for the money but 4500 rpm ? that sucks
    Bakersfield, CA
    Quote Originally Posted by 1bdhondo View Post
    I agree. Hell, even the 8.1L is (only) 5100!
    Not sure what the whole 4500 thing is about.
    ca
    all those parts brand new for 6-7k lol crazy
    Why would you use forged pistons in an engine that spins 4500, and 475 HP?
    Lot of OEM engines out there making more power, at higher RPM, some even turbo'd with silicon alloy die cast pistons.
    The fact that the same assembly is available as CNG LPG may have played a huge part in that decision
    Senior Member bp298's Avatar
    LHC
    it's a long block for a truck. not a complete engine...
