Race arrow and Gale Banks/PFM turbo setups questions.
Results 1 to 14 of 23
    Nov 2008
    Default Race arrow and Gale Banks/PFM turbo setups questions.
    I need some general info on these systems. They see like a pretty good bang for the buck. Seems like used systems are in the $2500-$3500 range. Will they support 700-800 hp on a 500+ CI Chevy? What if you changed them from draw through to blow through? I am looking at putting one in my Placecraft mini daycruiser. Not concerned with building a drag boat engine but more of a high speed lake cruiser. Any general info and thoughts would be appreciated. Thanks, Jason.
    Registered Parker Allstar SFV2RVR's Avatar
    SFV/PARKER
    My 460ci with a Race Aero system made 900+ hp @ 10lbs of boost on 91 octane.
    Quote Originally Posted by cc23 View Post
    Keep in mind that the Rajay 301E1.0 turbos were chosen to run on a 454 base engine, so you may want a larger turbo, or at least a larger exhaust housing on a 500 cu in engine, otherwise no problem making the power.
    Placentia, CA
    My 496 Race Arrow is over 1000 hp at 17# boost on E-85 with RayJay 301E's.
    steveo143 AKA DiMarco 21 II
    okie, lake Texoma
    +1
    And if you change it over to blowthrough it will run cleaner, start easier and you wont have to worry about vacuum drawing oil from the seals in the turbos. Also a little more power potential because the turbos will only be moving air.
    H8-2-W8
    [email protected] first pass
    Nov 2008
    Thanks Guys!
    What about running through transom exhaust with these units? I see it on the Race Arrow setup,what about the Banks? I would like to run though transom and possibly with a engine cover.
    +1
    But if you convert the rayjay turbo set-up over to a blow through, you lose the benefit of the intercooler that most are set up with.
    In that regard, I feel you lose horsepower potential by not running the intercooler.
    +1
    That's fine if you want to fabricate something, but I have done plenty of "old school" turbo engines that are reliable, start easily, and don't blow oil out the exhaust from the turbos.
    Quote Originally Posted by steveo143 View Post
    When did you get it dynoed? Might be fun to find a set of 1.3 housings and see what happens on the big end.
    okie, lake Texoma
    I would mod that cooler to set on the carb
    H8-2-W8
    okie, lake Texoma
    I know that the old draw through deals ran OK once started, what I was referring to is when the engine has been setting for a week or two, when you pump the throttle you aren't putting fuel into the manifold, you are putting it into the carb box and have to crank till it finally makes its way to the engine. Putting the carb on the manifold cures this.
    H8-2-W8
    They are not difficult to start, even after sitting for months. I raced a Schiada with a Gentry system for a number of years.
    Fuel injected would be even better too, but for a low dollar, reliable setup, the old draw through systems are great.
    SFV/PARKER
    Thanks Guys!
    I ran my race aero setup with a hatch also and thru transom exhaust. Had the banks system on there before the race aero system. Here is a pic with the hatch on it. Still pretty low profile!
    Sep 2009
    This is how I plan on making my Banks set up into a blow thru deal. I had the cooler machined to fit on top of the carb. This is just a mock up and not the carb and manifold I will probably use.
Name:	blow thru turbo 001.jpg
ID:	459370   Click image for larger version.
Name:	blow thru turbo 002.jpg
ID:	459378   Click image for larger version.
Name:	blow thru turbo 003.jpg
