What I did last weekend...more 6061 billet porn
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 54
    Default What I did last weekend...more 6061 billet porn
    Seems I have no home, no more "gearheads" section.
    Since I have to pick one forum, I figured the V-drive guys would appreciate the billet porn the most.
    So I am working on a billet blower plenum/intake for Nissan V-6 in a sandrail. It is modeled after a cobbled together stock manifold with a plate welded on top for the Whipple/Lycoming supercharger.
    I have only finished the top so far.
    Brian
    Default Stock with reference holes drilled and ready to go under the knife
    Default O-ring groove cut, holes drilled and tapped
    Default Blower intake roughed out
    Gone
    Sparks, Nevada
    You need movies.
    Default Top side finished
    Senior Member RhinoWood's Avatar
    Sacramento, California, United States
    Brian,
    It is very much appreciated in here. Looks very interesting. looking forward to progress pictures. I for one have always enjoyed watching your in progress projects.
    Thanks, and keep them coming!
    Wood
    Quote Originally Posted by RhinoWood View Post
    Brian,
    Wood
    Thanks for the cool words!!!
    I was told it was the motor out of the 87-89 Maxima or maybe a 300ZX? I am not sure about that.
    It is running some kind of an early type of aftermarket FI computer(Aerotech or maybe Autotronic) since this car was originally built I think in 89 or so with an engine out of a wrecked car that had 250 miles on it
    I don't know what kind of hood clearance is on a G-35, but like most new cars, doubful. The manifold itself will be no taller that the stock manifold if that helps.
    Gain?
    Boost?
    HH magnacharger?
    No oxide as far as I know, didn't ask for it either, not enough transmission anyway.
    Quote Originally Posted by ptz View Post
    hey man...
    same engine as a g-35 ?
    will it fit under the hood ?
    they runnin them with the stock ecm ? or motech ? (sp ?)
    how much gain ?
    how much boost ?
    does it work better than a high helix magnacharger ?
    are you making a nitrous sandwich plate too ? with annular discharge holes?
    i bet the trashcan is full of peperoni pizza boxes and pepsi bottles ? LOL !
    Default I'll assume you mean MACHINING movies.....
    You need movies.
    I have tried that before, problem is with the coolant spray, it would mostly turn into a shower scene.
    You aren't looking for THAT are you?
    Brian
  13. #12
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Nice work,Damn sure interesting
  14. #13
    Quote Originally Posted by SR View Post
    Thanks!!!
  15. #14
    Just for reference, I have about 8-10 hrs for the concept to a working design/programs and 8-10 hours of machine-time.
    Brian
