Too much cfm?
Results 1 to 5 of 5
Too much cfm?
    Senior Member Keithwidney's Avatar
    Apr 2013
    Default Too much cfm?
    OK i have a pretty stock 460 bbf with a tunnel ram .i currently have dual edelbrock650's and thinking about switching to holleys. My question is do I stay with dual 650 or is that too much for a stock 460.
    RPM range ?
    Max rpm you turn it?
    all else fails call John at C&J Engineering and he can tune anything to run on it
    Apr 2013
    I have not ran the boat yet .bought it tore the motor down to inspect and do some cleaning up. It has a panther pump for now, hopefully a Berkley next off season.its a family boat for cruising with short burst running it hard . I don' know where the rpm's will run .
    Yes it is to much. But it will work and look cool. Right Scott
    Quote Originally Posted by Keithwidney View Post
    It'll work just fine.
