E-85 and high compression N/a
Results 1 to 14 of 67
    custom member raped southwind's Avatar
    so-cal
    Default E-85 and high compression N/a
    Looking for some info on e-85.
    Im trying to figure out what to do with my motor set-up for next yr. Current motor is a 565 that i picked up as parts to put something together. I have been told that it has lived on c-19 or c-20 ( i forget) all its life. Motor has a Static compression ratio of 14.6. Anyone have any luck running this type of compression with e-85, Or how high have you had luck with,
    Thanks in advance
    Tower Park Resort, Lodi, CA
    Click the link below to send a PM to Master Sergeant. He's running a very similar combo and may be able to help ya out.
    PM Master Sergeant
    Placentia, CA
    I'm at 131/2x1 on the PS 303 motor.
    steveo143 AKA DiMarco 21 II
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    My 572 14.5 - 1 compression ratio runs well on E85. I test the fuel for ethanol/gas ratio and adjust if neededeach time I buy from the pump to ensure 85% ethanol 15% gas. Your mileage willdecrease by 30% which can be a bummer with a lake boat. You will need a goodfuel delivery system. For a normally aspirated deal like mine you may have amidrange stumble in the engine. My engine idles fine but will stumble a bituntil about 4K rmp then it will clear up. I am told the specific gravity of thefuel has something to do with that. I am told blown or turboengines do not have this problem. The engine makes 850hp at 5900rpm. I like the fuel and would not change it.
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by Master Sergeant View Post
    Cool..my junk is 14.1..and no stumble on 110,...junk yard deal 750hp
    Lake Havasu
    What do you pay per gallon?
    Peoria, AZ
    I have done a few bigger cube BBC with 13.5 to 1, one with steel heads. They were happy as can be, but never done anything that high yet.
    Master Sargent, you may want to play with your IFR or intermediate circuit to smooth out the "Dead Spot". That has nothing to do with the type of fuel. Sounds like you have one heck of a stout combo. Sounds like fun!
    Paul
    Paul
    If the carbs are 3 circuit Dominators, I would head straight to the intermediate circuit if its happening at that RPM.
    What I can't tell from the post is, is it laying down, or is breaking up.
    Its its laying down, there is a possibility that its not getting on the main quick enough and running on the intermediate up to that point.
    E85 is pretty viscous and it doesn't flow as easily as gasoline. You not only need more, but its harder to move.
    Who did the carbs? QF conversion???
    Lake Havasu
    Performance carb PC did the conversion. It was sent back to them and looked at with no change. Joey Grose who built the engine worked with PC carbs to try a few things with no improvements. I was told that it was typical for an E85 NA build and just learned to live with it. I have found that there is a lot of controversy when it comes to E85 conversions.
    There is nothing controversial about E85 conversions, there are good ones and not so good, and bad.
    I can almost bet you are lean in that spot, if not everywhere else. You wouldn't the first one with PC carbs at was. Seen couple motors go poof. 2 in one weekend------in the same boat. If you don't fix it, I suggest you don't hang out at that rpm range too long.
    Not saying its not possible to be too rich in that range, but with the rich-lean tuning window of E85, and the fact that E85 conversions tend to be too lean if anything, my money says its a lean condition.
    Apr 2010
    Rocklin, Calif.
    In a drum, about $6 bucks..a 5, $10 bucks...But I know what I have...
    Cool. Feel free to tell us.
    I bought 5 gallons of pump, VP, Sunoco, Torco, and Ignite e85 and 114, and I am still not 100% sure whats in any of them.
    You have good idea whats not in it.
    A BETTER description would be, you know its the same as the last time you bought , and will be the next time you buy it. What ever it is, its the same each time.
    Lake Havasu
    $6 is a good price
    Lake Havasu
    I bought an RPM Performance wideband o2 sensor and found the afr is around 9 to 10 at full throttle and closer to 12 at 4000 rpm
    (red line is rpm) (black is O2)
