compression ratio,boost & hp
Results 1 to 14 of 40
    sacramento
    Default compression ratio,boost & hp
    i was thinking of bumping up my compression from @ 8.5:1 to 9:1 to get better off the line results. will i loose power on the top end beings as i will have less volume to pack with boost? boost will be run at @12,20,&@25psi+. might wanna run e85 or alcohol temporarilly for playtime. at what point does lowering compression help/when does it not? 35psi,nitro,?
    Final compression ratio=[(Boost/14.7)+1] x Compression Ratio
    With those boost numbers you may run into some reliability problems.
    Tower Park Resort, Lodi, CA
    Paul,
    In your current application, I don't think you would notice much, if any difference at all in the way it performs out of the hole.
    Two reasons:
    1) It's a jet and isn't loaded at the punch like a stick shift car or hard biting prop... It doesn't have to pull itself through the lower rpm range. You may knock a slight fraction of a fraction of a second off the time it takes to hit max rpm.
    2) It's a turbo and not spooled at the hit either.
    There may be ever so slight benefits to be had, but you'd be pushing your luck with your current set-up...
    Any loss in volumetric efficiency would occur at/near peak torque rpm. After that, it becomes a cylinder filling game of how much you can get in while the valve's open less and less time per intake stroke. If everything is in proper tune and you're using the appropriate fuel for the boost level, the extra half point would bolster the entire torque curve, even the slight VE loss at peak TQ will show a gain.
    If you want to really boogie. Sell the Banks system and piece together a blow through system with new turbos... you'll make more power with less boost, and a lot more with the same boost. Just say'n. Probably spool sooner too.
    Been following your build thread and you continually inspire me with your tenacity. Keep it up Paul!
    okie, lake Texoma
    H8-2-W8
    [email protected] first pass
    Paul,
    Two reasons:
    Very well explained!
    I don't know how big this thing is, but the idea of 20, 25 or 35 psi from a Banks setup is pretty lofty.
    Pushing 25 lbs at that compression ratio on E85 is doable, if you are on your tune. My guess is you're not, or you wouldn't be on here asking.
    if you can't thoroughly conquer the above on E85, forget nitro. That's like starting a new career as a dog trainer, and starting with adult wild wolves. You WILL get bit!!!!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Nitro a very delicate operation. Requires bravery. Ranks right up there with letting a dry fart out with a bad case of diarrhea. While wearing an expensive pair of designer underwear.
    In other words, I wouldn't want to try it.
    QE 439 Twin Turbo
    Apr 2010
    Rocklin, Calif.
    Paul, go NITRO!!!!
    Thank you, I appreciate the acknowledgement.
    But you learn, really fast!
    Haulina29 AFUEL7067's Avatar
    Thumbs down
    25 lbs of boost is doable lmao , 24 to 1 on e85 with a Banks system ? .9 to 1 with 12 lbs is like 16 to 1 ?
    Quote Originally Posted by AFUEL7067 View Post
    Like I said, with a Banks, thats a pretty lofty plan.
    12+ plus to 1 with 14 lbs on E85 is being done. They're losing a few, but they'll get the handle on it.
    25 to 1 final on gas is doable.
    The big question is on a antiquated Banks system if you could make 25 pounds wich you cant what would the exhaust pressure be ? Were not talkin roots with zoomies .?
    I see that someone finally paid attention to the formula I put up in post #2. (If it's even possible to make that much boost with that system?)
