BBC head gasket
Results 1 to 14 of 21
BBC head gasket
    Default BBC head gasket
    Does any manufacturer have a .021 steel gasket that will fit a 4.031 bore? What is the best sealer for steel?
    SCE has a copper 4.060
    Mr Gasket has a steel that is .018 with 4.100 bore.
    Most of the gaskets you find will be 4.100
    Tri-Cities, TN
    We carry a 4.100" coated stainless gasket .020"
    We carry a 4.130" graphite shim gasket .028"
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Quote Originally Posted by BadBehavior View Post
    Could you mean 4.31? Don't know of any BB Chevys with 4.03 bore.
    Is it ok to run copper without o-rings/receiver groves?
    Sure,, make sure to seal around water ports. I use a thin coat of hi temp silicone (it goes on thinner than regular silicone)
    Personally I wouldn't. I tried it once when I was very young and vey dumb on a mild SBF and didn't work out well at all. There is reason gaskets have a fire ring.
    I'm thinking its a SBC. Probably for a SE, thinking he is going to gain some compression with a gasket that's no bigger than needed to clear the bore.
    just a wild ass guess.
    Yeah, except the title of the thread is "BBC head gasket"...
    I have only done it once or twice, when I wasn't so young. Must have been to get a specific gasket thickness, but no problems reported. I think one was a mild marine blown engine.
    I probably should have asked "why?" as a preface to my reply, there are lots of alternatives that won't require as much time and care to install. I have one high compression dirt track engine that I build that we still run copper head gaskets on.
    MMMMmmmmmm
    .100 over 366 truck?? Naw!
    You don have to ask yourself, whats with the 4.031
    I dont wanna jack this guys thread....but it caught my eye because I have wanted to improve the quench on my 557 with a similar thickness gasket. I had never heard of quench when it was put together. My ex motor guy left me about .022 in the hole. I am pretty sure my block isnt currently smooth enough for an mls type. I knew you could get copper in a variety of thickness....but assumed it needed to be o-ringed ect. I have periodically heard the term shim thrown out there. I have zero clue if a shim can be used instead of a gasket....or if they were meant to be used with a gasket. Hopefully at least some of the things I am asking the OP would want to know also.
    If it has aluminum heads, I don't recommend running a embossed steel shim gasket.
